I can't seem to turn on any of the burners on the top of the store. I checked the manual, the cooktop is not locked. (I locked and unlocked it per the directions.) Help!
SOURCE: cooktop light stays on when cool
Please be more specific. A. What is the "plate cut-out"? B. How does one access it?
SOURCE: low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
SOURCE: Kenmore 44083 Cooktop
should be an unlock button.....press and hold the button until it unlocks
SOURCE: Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
SOURCE: new cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
Here
is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop
Range Stove spark ignition does not work
heatman101
