Epson Stylus NX400 InkJet Printer Logo
Cynthia Sippio Posted on Apr 03, 2014
Not printing after refill - Epson Stylus NX400 InkJet Printer
Sam Oldman
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Apr 13, 2014
Sam Oldman
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2888
Points
12
Most Epson printers have to charge the cartridge after refilling. in order to do this you must go through two or three cycles of head cleaning followed by nozzle checks. If you do this through software it will progressively get stronger and stronger until after the third cleaning cycle the cartridge should be working. do not use the buttons on the printer to
Refilled black cartridge 36 on my 5650 won't work
The cartridge is electronically dead. This is a common occurrence from improper refilling. To be correctly refilled it must be done under a vacuum to prevent air from entering the print head, which has likely happened. As ink flows through the print head it acts as coolant in an engine, when air is introduced the print head cannot cool, over heats, and ruins the cartridge. These cartridges are difficult enough for us professionals to refill successfully, my recommendation is to leave it to us, or buy original. A refilled integrated print head cartridge will always continue to read as empty because there is no way to reset the cartridge, the manufactures do this on purpose. Lexmark cartridges in general are designed to only last one cycle anyways, multiple refills is attained only with proper technique.
My printer isn't printing ink. I refilled the
the life or ur cartridge is over... its unable to make any contact with the printing circuit, a cartiadge can only be refilled 2ce or 3ce not more than that :(
2answers
I had my cartriges refilled and now its not printing correctly. actually printing in all yellow. I've tried cleaning the heads and turning off printer to rest. I've tried to align and clean printer heads....
Unfortunately in my opinion your cartridge has been compromised. Hopefully you did not pay for this service. You should replace that cartridge immediately. When it comes to cartridge "refilling" if you are not going to "do it yourself" don't even let someone else do the deed even for "FREE"
1helpful
2answers
Can't print after i refill the cartridge, why is that?
If refills are done properly they will NOT damage your printer and they WILL produce good quality prints. If you refilled the cartridge yourself or at Walgreens/Costco/OfficeMax it is likely there is either an air pocket between the ink supply and the print head or the electronics on your cartridge have failed. I recommend Cartridge World for refills. They produce a high quality product that has a 100% satisfaction guarantee. If one of these stores is not in your area, I recommend Office Depot brand refilled cartridges.
Printer slow after putting in a refilled cartridge
Sounds like the TSR is out on your cartridge. The TSR is the heat sensor for your print head. If the TSR goes out it cannot tell the printer that the temp at the print head is at ok levels. So the printer assumes the print head is really hot and at risk of fusing its nozzles so it prints really slow (the faster the printing the hotter the print head gets). It is possible, but not very likely, that the ink in the cartridge is of such low quality that it is not cooling the print head properly as it flows through the nozzles. Thus the TSR tells the printer to print really slow so you don't burn up nozzles. If you got this cartridge refilled at a store or on-line I would return it and get your money back. I recommend Cartridge World for refills because if this happens to one of their refills they will give you a new refill at no charge.
3helpful
2answers
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Cartridhge not printing properly
it must be not refilled properly.check the cartridge in another printer.from where have you refilled.or try another cartridge in your printer.there is always a problem after refilling
Printer refills
Some refills won't work on some printers, because the printer actually reads a chip on the print cartridge, a good refil will have been reset, if you did it yourself, or if the company you bought it from did apply the chip reset device on it, the printer will never allow you to use it, thanks HP for the wonderful idea grrr. Be careful with refills anyhow, because some printers use easy clogging ink and refills can be dangerous.
3answers
Printing problems
U have faulty print cartridges. {rint cartridges are not like oner cartridges, after they run out, they are not going to give u the quality printing , especially if the cartridge isnt refilled by a professional.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
