SOURCE: HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
SOURCE: HP Laserjet #3015. Double feeds when feeding
Separation pad (not feed rollers), is responsible for preventing double feeding. Clean or replace it.
As for toner low...hold the "go" or "online" button until both (all) lights flash then release, this should give you a supplies status page.
SOURCE: HP color laserjet 1600 wonte printe new toner color.
The supply status report is based on what the kill chip is reporting to the printer. If that particular color is not printing then it is likely that current is not flowing though a particular component in the cartridge. I would return the cartridge and get a replacement.
SOURCE: HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
