Want to do department setting
Turn key to program mode.
Turn power off.
Hold down JOURNAL FEED while you turn power on.
You should see 'LLLLLLLLLL' on the display
The machine is now ready for memory clear. Use the initialisation code from the programming manual which you obtain by using the table to work out the code for your country. Type the code at this point and press SUBTOTAL. The machine is now ready for your new menu etc.
If you need the programming manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
SOURCE: te-2200 can't calculate tax-on-tax
Hi.
Have you set your departments or PLUs to use both taxes?
SOURCE: How do i reset the casio te-2200-1 cash register
This is not advisable as you will lose a large amount of settings and data. If you are not familiar with memory allocation procedure, key allocation procedure, machine features settings and function settings, then it would pay to avoid a full RAM clear. It would be much easier to edit the existing programming to suit your business.
If you still want to RAM clear the machine and start again, you will need the tables from the Casio TE-2200 dealer manual:
To program the basics such as Item names/ prices and receipt message, the user manual is what you need:http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_users_manual.html
SOURCE: how reset the cash register TE 2200
Are you trying to reset the daily report?Try turning key to Z1 then press CASH button
