I can't install apps
SOURCE: Nokia N73 Certification Error
whenever i install smartmovie player or other softwares in my n73 , it shows the error "expired certificate". plz help me ,
SOURCE: my n70 is reset to factoer settings nd wn i
Have you tried changing the date of your Phone? If not, set it to the exact time shown on your PC. Since the PC is synching with the Phone, the time should also be aligned when installing any software or application via PC to your phone. There are different terms and causes though, but doing as I said will help you fix it. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
SOURCE: the security code in my
first you have to change your date (for example change the year to 2007) while u connect the use
SOURCE: i can not access my
my n72 didnt connect with data cable.i tried many other n72 cable but it didnt show in pc or mobile.provide solution
Hiren
SOURCE: no valid certificate
This error comes when the particular firmware of a phone is out-dated.So, update your phone's firmware via GPRS or by flash with up-to-date file version.So, here if you wish to do it by yourself Click here1.or you can contact mobile repairing shop.Select and download your 5130 flash file from All nokia bb5 flash file.Thank you for visit fixya
