My motherboard and monitor have hdmi ports and a hdmi cable connecting them. When I sellect hdmi mode on the monitor, the screen goes black and then a message comes back saying no hdmi signal. Is there...
I'm not sure about the system or monitor that you're using, but usually for Windows systems, you have to change the display within the system before the screen will actually show on the monitor through something other than the standard display port. If you reply with your OS, then I might be of more help, but assuming you have Windows 7, you must plug the hdmi cord in, right-click on the desktop, and select Screen Resolution. Then select the option (likely "HDMI") under Display that you are currently not using. At this point, your current screen will most likely go black. Switch you monitor to hdmi mode, and then you should be able to use your monitor via HDMI. If you have any questions, please feel free to contact me, or simply comment.
