Bryant air condition fan outside will not coming on when I turn in on in the inside. The unit just blows air, and does not get cold. What can I do to fix this problem?
Possible common causes are:
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Does anything come on (conpressor) in the condensor outside? If you put your ear to the outside unit can you hear a 60 cycle buzz?
check your circuit breakers labeled a/c unit inside your house panel
you have a electric box near the outdoor unit it will contain fuses or a circuit breaker check it
check wiring outside near the unit to be sure it intact(small thermostat wire if it is not encased)
look for a reset button near where the refrigeration lines hook up
