Lexmark X6650 4-In-One Wireless InkJet Printer Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing errors When I go to print a multiple page document from Word 2007, only the last page of the document prints and the monitor on the printer indicates that the print job is complete.
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Jun 15, 2009
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
23705
Points
259
Try printing one page at a time and see what happens. Repost!!
Will not print from the computer to the printer. I brought up a picture and pushed print and it just pulled in the paper and it was blank
* Check your warranty. Call for support.
*** Following is for information only.***
* Brand, Model for specific solutions.
* Computers and printers perform many functions.
* Just printing B/W documents are a thing of the past.
* Just printing a document requires the user to identify:
* Size of paper to be used. A4, 5x8", 8x10, banner, etc.
* Quality of paper; Plain, semi gloss, bright white, photo, etc.
* Orientation of document or picture; Portrait or Landscape
* Multiple copy.
* Size of document; Standard paper, Multiple (expanded) poster, Shrink (Reduced to fit page), Reduced to wallet size., etc.
* Color shift (effects) Print in grey scale.
* Print in reverse for T-shirt transfers or window posters.
* many more options depending on the printer. (some print on cakes)
* The point is that these or most of these have to be set up by the user EACH TIME you need to print something. The printer may be set for poster sized pictures but you just want to print a simple letter. This poster setting (depending on how many sheets per poster) may be the upper right corner of the document is blank. It did print but it started in an area that does not have anything to print.
* Another issue with printing (more common) is how many sheets are you printing. Depending on your CPU speed, each page needs to be processed (rendered) to be accepted by the printer. My Lenovo ideapad takes 2-3 mins to render 1 page. Printing 15 pages (or copy) takes over 30 mins to render before it prints the first sheet.
* Which order of print? Was the last page printed first? Is the last page blank?
* Wireless printers also take time to transfer data to the print buffer. This is also depends on your router or WiFi speed. (or network)
* To check your setup use the "Preview" option. Not how the document is pictured on the printed sheet. Pre-view saves on wasting paper on miss prints due to incorrect settings.
* Check your printer manual on setting up for a specific paper, document size, quality, and other issues.
Aloha, ukeboy57
PS, the issue of lost connection (WiFi) will stop the print. Eject the last page (partial print). Some machines will eject page only after a restart or reset.
* Perform a "Test Print" using the printer test mode (to check if the printer is out of ink.)
* Perform a print of a single page letter from the computer to test the connection to printer.
* Use the computer to check the printer app. look at the ink levels. Perform a system check of the printer operations.
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
When printing multiple pages last few pages come out garbled
You may need to increase the amount of ram in your printer. Or turn it off then on, then try printing the large document. Do this before every print job, if it fixes your error, then you need more ram.
Won't print words!
sounds like a couple of things....
the document program your using, when printing, check to see what is printing (pages) you can select one, current page or multiple. also check the attributes for printing.
check the settings for the printer, you might be out of ink
lastly, in the document, go to the Page File and scroll down to see if the shaded areas need to be 'set to back'
hope this helps and good luck
2helpful
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Printer only prints one page of multiple page document
i dont know how to conect lexmark printer X4250 to my computer
2answers
Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
2helpful
Prints a decription of my print job on one page ... additional unwanted page.
It sounds like you are printing from Word 2007. Go to the Office Button, Print, Print, Options and under "Printing Options" uncheck the "Print Document Properties" box.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
