I changed the default from Microsoft printer to hp jet pro 8600 printer and it went to pause I have pulled the power plug for a few seconds and nothing happen.tried printing in different ways it goes to the priniter but pause there
Please download and run the HP Print and Scan Doctor from www.hp.com/go/tools to resolve the issue.
If issue still persists, let me know if there are any error messages displayed on the printer.
SOURCE: hp laser jet 1020 has refuse to print
all you have to do is lift the top cover where the toner goes and remove the toner, now when u look inside you can clearly see the white colr spool or roller. This roller due to usage tends to pop up a little, so with one of ur fingers push it down and u will hear a click noise thats it, clean up if u see any dust load the toner back close cover and ur back in business.
good luck
raz
SOURCE: HP 2840 printer pause will not resume
uninstall your printer and then re-install it that should fix your issue,it could be a bad version of an updated driver that is causing the problem
SOURCE: hp deskjet 6540 power adapter turns on but printer doesn't
This printer have a problem on HP circuit board. Usually its grounded due to ink waste, or not using it like what you said it took about three months. Here is a tip if your printer HP is still under warranty then you can send or contact to HP Center or the one you buy from it. To be sure that your printer is working back normally.
SOURCE: how to change a fuse in the hp 2800 printer, power up problems
There are 2 fuses inside the power supply unit.
The hard part is getting to the power supply! The power supply is located at the left side of the printer and in the front (the opposite side of the cartridges).
You have to remove the side and top covers.
There are some hidden screws. One is under the button faceplate that you will also have to remove. The entire procedure is tricky especially without a service manual. Unfortunately I couldn’t locate a manual.
Caution always disconnect the power lines and allow some time for capacitors discharge before you attempt any repairs.
I hope you have some luck with yours !!
