When we print from Oracle ERP system to Konica Minolta 554, only blank pages are being printed.
Does the machine print ok with word, web papge pdf, etc if so its the oracle issue, or just the oracle file try other files?
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
