My phone thinks that there are too many saved messages. Every time I try to send or receive 1 I have to delete 1, 2, 3 or even 4 old messages. By the rate I'm going, I will reach 0 saved messages soon and won't have anyhting to sacrifice to the confused software anymore. I failed trying to install an update some years ago and now there are no more updates available online for the w810i. I don't know whether that would even solve my problem. Or is there a reset option that cleanses and rejuviates my phone. Or any other option? I like it, I don't want to give it up...!
Well most phones have an option for a factory reset. Thats usually in the options or tools and settings menu of the phone. There is a possibility that the system memory is getting take up somewhere else and since the messages are the smallest data amount they are being mentioned. But I'm also not sure if older devices make that differentiation or not. Other than that, you may be able to find a replacement model online or you will have to upgrade because your phone is the point where it is just failing due to age.
SOURCE: k800i-operation failed message for games and applications folder
I have had this problem for a few weeks and finally sent it back for reflashing as that seems to be the only solution. I got it back and it still does it but it has been reflashed since it has the latest revision (which it didn't have before)... It has to go back :(
SOURCE: SE W810i says message inbox full, but no messages there!
okay well your phone needs to be reflash, what you need to do is go to www.topsony.com..to get the flash file which you have to pay for this well fix the problems on your phone.
SOURCE: Failed update on a K800i
to get into recovery mode you need to hold the C button as you connect it to the usb cable - usb cable plugged to pc first.
What software are you using? SE Update tool or wotan or SEtools or cruiser?
SOURCE: error 'sending failed message barred'
get check ur message centre no.. it moght be wrong ....
or contect ur castumer care service operator
please rate me
