LeapFrog Little Leaps Grow With Me Learning System Logo
Posted on Jun 15, 2009
I have a Emerson dvd/vcr and need the codes please
I have aEmerson dvd/vcr and need the codes please
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Jun 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
4372
Points
6
The quick code for an emerson dvd player is 44
If that doesn't work the manual setup codes are 043 or 059
If the above fails, try a Manual Setup using the Additional Manual Setup Codes below, when prompted -
1. Start Manual Setup by pressing MENU on your DVD player remote control during the Setup process. Select “Manual Setup” from the menu and follow the instructions on screen.
2. When prompted, try the first three-digit code from the list of Additional Manual Setup Codes, below.
3. If the above fails, try the next three-digit code in the list, and so on.
Additional Manual Setup Codes:
018
030
035
005
150
151
043
058
011
147
148
016
004
002
144
007
009
146
013
020
027
133
042
129
149
Hope this helps!
2answers
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Please inide code for tv emerson
Hello
You havent specified what type of Emerson combo is yours. Anyway I hereby posts some Emerson combo codes.
TV/VCR
0227 0233 0254 0264
.... 0265 0266 0310 0325 [0039 0252]
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR
TV/DVD combo
0456
TV/VCR/DVD combo
0456 [0458 0227]
DVD/VCR combo
0456 [0458 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
1helpful
Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
I need the remote codes for an emerson dvd/vcr combo
i need the exact brand and model of the remote.
thanks
tom
1helpful
2answers
Need codes for rca universal remcon to emerson vcr and need codes for emerson vcr and coby 224 dvd
Try these codes for the emerson:
Code 003 for Emerson VCR Code 007 for Emerson VCR Code 012 for Emerson VCR Code 014 for Emerson VCR Code 015 for Emerson VCR Code 021 for Emerson VCR Code 024 for Emerson VCR Code 025 for Emerson VCR Code 026 for Emerson VCR Code 029 for Emerson VCR Code 031 for Emerson VCR Code 032 for Emerson VCR Code 033 for Emerson VCR Code 038 for Emerson VCR Code 041 for Emerson VCR Code 054 for Emerson VCR Code 065 for Emerson VCR Code 116 for Emerson VCR Code 130 for Emerson VCR
and I wasn't able to find any for the dvd player :/
20helpful
4answers
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
1helpful
2answers
Innovage Universal Remote
I have a unversal remote and i can not get it to work for the dvd/vdr I have from magnavox....can someone please help me
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
