Cars & Trucks Logo
a
annabrown Posted on Apr 01, 2014
Making noise cylder is miss firer
jairo flores
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Apr 01, 2014
jairo flores
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
6
Helped
2381
Points
25
Check the coil if coil is ok spark plug if there are ok may damage in emission valve or injectors code relate it to the problems are p0300 p0301 p0302 p0303 p0304 p0305 p0306 p0307 p0308
2answers
Where is turn signal flasher located on unidentified vehicle?
The turn signal flashers on unidentified vehicles are usually above the pedals down under the dashboard on the driver's side. If you turn on a signal and look up into the wiring under the dash you should hear the clicking noise which might help you to locate the flasher unit. If the signal flasher isn't working or making noise, try the emergency flasher. The flasher units usually are close to each other and look alike.
Good luck.
Ihave a missed firer
ever do a 60k tuneup this decade.
if this is knocking combustion detonation, the engine will self destruct soon. ping or knock is cause by lean mixtures and very hot combustion, all very bad, do not go up hills that makes this worse.
i say get a shop to check it out. before it gets too costly to fix.
easy on any 91 car.
1998 buick park ave white smoke coming out of tail pipe and miss firering
White smoke usually represents presence of oil burning off while the engine is firing along. It can cause misfires if there's enough oil to prevent the spark plug from firing properly. I had this happen on my car and it was caused by a failing Valve Cover Gasket. It might make sense replacing the Valve Cover and the Gasket, just make sure you use the Sealant if you do it yourself to ensure the valve cover and gasket seal to the Engine.
Two cylinders are miss fireing
bummer,has to be the module underneath.
If the plug wires get bad it\'s really hard on the coil ,
May want to put a set on with the module,
1helpful
Trk ran find shut it off,when tryed restart firered up an died.no fuel checked fuel filter it was pluged completely,installed new one an still wont start.will firer with starting fuild.every so offen will...
its possible you have a filter in your tank or farther up your line near the fuel rail. look for another filter and make sure you have fuel to the filter you just replaced. could have clogged it again if you have alot of rust and setament in your tank.
1helpful
2answers
While idling, the engine sputters. check engine light on, reading misfire in cylinder four. Have replaced both coils, all wires, and all plugs. Still no help. I've come to a dead end. Anybody with ideas?.
Hi, this may be a dirty injector. Try putting some injector cleaner in the gas tank to see if that will clear it up. If not, you may need to pull up the fuel rail and check the injector flow pattern.
1helpful
2001 saturn sc missfire on cylder 1
Possible injector?Check compression in that cylinder.May have bad rings..
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
1helpful
My fiat brava is miss firing i have changed the plugs but it still miss firer
Check your rotor arm, distributor cap, HT leads and coil. The fault could lie with any one of the above.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
