Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
Stop the tape.
Ensure the tape has been rewound to the beginning of the video recording.
Play the tape.
If the issue is not resolved, stop the tape and remove it from the camcorder.
Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
Reinsert the tape into the camcorder.
Play the tape.
Insert a different tape with video footage into the camcorder.
You have dirty heads, hence the blue screen, either try using a head cleaning tape, although these do not always do a through job, or if you remove the top cover & using a head cleaner fluid, VERY GENTLY wipe the heads at the sides of the round silver drum using either a head cleaner stick with the fluid or a piece of sturdy card. DO NOT put too pressure against the head or you will damage them completly & would need replacement heads. Leave them a few minutes to dry then try playing a tape once more.
Hi, This message appears when the loading tape path become misaligned (mechanically unstable). Your camera just need mechanical adjustment from any expert and it will work fine again. Contact any service man for this. Thanks for using fixya.
There is a guide that you can get that will solve all errors like this and black screens it has been a lifesaver for me. Have a look at http://www.freegamesforwii.info/?cat=11 they have info on where to get this guide. I cant remeber the site off the top of my head,.
Most models of cameras have a built in feature to give you a message and turn off if it has condensation on the inside components.
Powering back on during this period can cause damage to components. It should remain off in a warm dry area.
Condensation might occur in high humidity, or when switching from a cool location to a warmer place.
Try cleaning your video heads with a "cleaning tape" let it play for 10 seconds then pause.
If that solves nothing your camera may have permanent damage in which case JVC or a repair shop will have to replace parts.
your camcorder video head is dirty, use a brand new tape and playback for around 5 minutes or more, this will serve as your video head cleaner. you may try at least five times doing this: insert, play, eject,play, eject again. your camcorder has a built in videohead cleaner and activates only during insert, play or rec, and eject mode. If the problem is still there, manual videohead cleaning is needed, use clean bond paper and lighter fluid, damp the bond paper (Size about 1" by 3") with fluid and rub with care the videohead (not the bond paper!The vhead should be the one turning not the paper)by slowly turning the videohead against the paper. Be careful cause this is dangerous that you might brake the videohead permanently. apply only a slight force to the head.
