Panasonic KX-TG2356 Cordless Phone Logo
How to remove area code 1
I need to remove area code,(it's always appears after any calling number) because I stay in UAE, so I think this is the reason why the caller ID not showing, it' s showing the number, but not the name from phone book of the phone, while I saved it.
5 Related Answers
Anonymous
  • 65 Answers
  • Posted on Feb 05, 2008
SOURCE: Caller Id does not always show up
call panasonic 1-800-211-7262
SVMGRE
  • Posted on May 08, 2008
SOURCE: caller id
the digital answer machine did not torn on? Why?
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Dec 04, 2009
SOURCE: my caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Anonymous
  • 639 Answers
  • Posted on Jan 17, 2011
SOURCE: I just received KX-T7730 phone with an LCD screen
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Anonymous
  • Posted on Oct 09, 2011
SOURCE: CALLER ID NOT WORKING
not only Panasonic, most other brand phones imported from other countries wont work in in India ( caller ID). Panasonic phones of Panasonic India, will work.I think panasonic has to explain this. if there are networks which does not support this equipment, atleast they should mention this is their booklets, to avoid users roam around telecom offices. To my understanding, all the land phones of BSNL through out India are caller ID enabled by default and is free!.
2helpful
3answers
Need coupons for hotels in Albuquerque NM.
Do you think that Acquiring cheap hotels would be a good choice. I previously used coupons from Hotels here http://www.ezcouponsearch.com/Hotels-Coupons_cm_2715.aspx and that worked for me. I hope that this can help you getting work.
1helpful
How to call or use idd call in globe OFW sim in your cellphone
There are many ways to place an Idd call via globe OFW sim.
1. Promo 20 pesos for five-minute call to USA, Hongkong, Canada, Singapore, and Taiwan. 30 pesos for three-minute call to UAE, Saudi, and Kuwait
To register:
  • Text IDD20 send to 8888 OR Text IDD30 send to 8888
2. For 15 centavos per second calling to any countries
  • No need to register. Just dial 12800 (country code) (area code) (phone number)
How to call Phone to UAE? What is the UAE Phone code? What is my area code?
"971" is the country code for the UAE. Call with your international access dialing code. In the USA, it is "011". So making a call to the UAE forul be 011971 followed by the UAE phone number. From most cell phones, you can press and hold the "*" key which makes a "+" sign, and then dial the country code and phone number.
When a received call comes in the number shows 1-402 then the number.on call back the phone dials all 11 numbers,then i get a recording from windstream that says i dont need to dial the 1 and area code....
The caller ID in your area is set up to show the 1 plus the area code although not every area has yet to require you to dial the 1 before the number. In the near future it's possible you will have to dial the 1 even if you're calling a local number. I know of no way to change the phone settings in order to remove the 1 in the caller id. Unfortunately it looks like your only option will be to dial the number directly without the 1. Good luck!
2answers
Just bought a KA08 mini and can not get the name of the caller to apear on the screen on an incoming call.
You need the area code of the person's phone number saved with their contact information in your phonebook. So for example:
John Doe
555-664-5974
Hope it Helps!
Oct 27, 2009 • Cell Phones
2answers
How can i trace this number 0508481436
The area code 050 is invalid. Is this the full number?
Dan
My phone when I press for automatic dialing it adds a 1 in front of the number and the call wont get completed but if i dialed the number manually it wont add the 1 and the call gets completed. Balckberry...
When you do your automatic dialing, does the number include the area code? ie. mine is 937 (937-xxx-xxxx)
If you don't have the area code put in with the rest of the number, that may be your problem. 1 is the country code for USA, so normally when you see a number that says +11234567890, its country code, area code, phone number.
+1(country)123(area code)4567890(phone number)
So anyway, the only thing I can think of is to put the area code in the phone numbers in your address book if they are not already there. Other than that, I dont know.
1helpful
Area code
Here is a link to the site containing a pdf manual link and this is an excerpt for you :
Long Distance calls and Area Code Setting/Cancellation
While the present Caller ID information is displayed, pressing */tone/< will place
or remove the prefix "1" in the display to set the call for a long distance call, or
pressing #/> will set or cancel an area code (see page 30).
Storing Caller ID messages in the Phonebook
Messages shown in the Caller ID list can be stored in the phonebook. The phone
number and name of the party on the Caller ID list can be stored in memory.
1) When the phone is in standby mode, select the Caller ID message to be stored.
Then press the STORE soft key on the base or the EDIT soft key on the handset.
From the handset, then select E D I T ?. S t o r e / E d i t N a m e appears. If the Caller ID
message is already stored in memory, you will hear a beep and T h i s d a t a i s
a l r e a d y s t o r e d ! ! appears. The number will not be stored.
2) To complete the setting, follow the steps 3-8 in "Phonebook (Storing Phone
Numbers, Names, Distinctive Rings, and Speed Dial)" on pages 42-43.
Contacts
i don't use 1-000-000-0000 and my caller id works fine with text and calls
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
