There is not network setting in administration panel
SOURCE: Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
SOURCE: I need to scan to email using the c353 konica
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
SOURCE: I need the driver for
go to konicaminoltaus.com they have the drivers for all current models
SOURCE: i am having this error message with my konica
This is a tcr fault with the black i/u check the toner or i/u if tone has just been replaced check the seal on the unit sometimes the break and no toner comes through =if not look at replacing the i/u
To enter in service mode press the following key in that order:
Utility-Metercount-Check details_Stop-0-0-Stop-0-1 and select what you want.
