The BT box keeps switching itself off, then we have to wait while it reboots back up again. We have had this BT box about 4 years. The home hub from when we joined BT. If we can't get it working positively , we will cancel BT Vision.
SOURCE: While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
SOURCE: tv keeps switching itself off
When that happens - try unplugging the tv for a few minuets & plug it back in.. Sometimes it will reset its self.. Or it could be a bad sercut or maybe a falty power suply.. Electronics is usually process of illimination - unfortunately..
SOURCE: My LTV32w1 Westinghouse TV keeps shutting off
Ur tv power supply have dying leaking parts call capacitors.The board where the power a/c cord plug into it.That the power supply board.U know basic electronic's,have the tools and know basic soldering?Searches the power supply board for these dying leaking capacitors and replace them,ur tv will power up normal an last.These dying about to be dead are alway bulges up on tops or puff on it tops.These Capacitors must be replaced.Or tries websites like Shopjimy.com,Ebay.com to buy a whole refurbish power board for the replacement.
