I took the bobbin case apart and cleaned it all as per the manual and checked the needle and threading and everything seem OK. Can you please suggest something as I am in the middle of a project that I would like to finish as soon as possible. Thank you, Marie
Did you try changing the needle. Sometimes the needle can be slightly bent or blunt and we cant see it. Also, are you using the correct needle for the fabric you are sewing. What size needle are you using and what fabric are you sewing. Sometimes, also, changing to a new bobbin can help, don't know why, just does.
Try these suggestions
use a new needle
check to see if the top thread has come off the top thread take up lever
make sure the bobbin is turned the right way in the bobbin case
