Washing Machines Logo
l
lizz Posted on Mar 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Frigidaire front load washer Model FTF2140ES0 has stopped working. I hit the wash buttom and the washer turns on but water will not enter the machine. I have disconnected the hoses and made sure
I had this problem before and the tech used a turkey baster because something was clogged but I can't remember what he did.
Sammy Perlmutter
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 76 Answers
  • Posted on Mar 31, 2014
Sammy Perlmutter
Expert
Level 2:
New Friend:
Cheetah:
Answers
76
Questions
0
Helped
16815
Points
233
Clog input line to the cold or hot water on the machine Check drain filter on the machine..
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Apr 29, 2007
SOURCE: GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Anonymous
  • 351 Answers
  • Posted on Jun 23, 2009
SOURCE: Whirlpool front load washer LHW0050PQ4
hmm could be a belt, or motor or both or the cpu not sending juice to the motor.... any other details you could give me would be helpful
Anonymous
  • Posted on Jul 09, 2009
SOURCE: Kenmore washer "warm" wash cycle not above room temperature
aaa
Anonymous
  • Posted on Sep 06, 2009
SOURCE: I have Frigidaire Affinity washer that beeps and blinks "dr"
Actually don't buy a new door mechanism yet. There is a metal ring that holds the rubber tub to the rest of the washing machine. It has a spring at the bottom of that ring. Pull it down and you will be able to get the ring off. Carefully peel back the rubber tub on the right had side near the door latch. Reach in side and unplug the bottom connector for a few seconds and plug back up. (Do this all with the power on). Then put the rubber tub back around the frame and put the metal ring back on. This should solve your problem. I had the same issue not too long ago.
Frigidaire FTF2140ES0 Front Load Washer lock indicator light goes off, but will not spin.
Sounds like the electronic locking mechanism is malfunctioning. It is supposed to enguage before the high spin cycle. It is about a $20 part.
3helpful
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
1helpful
2answers
FTF2140ES0 Bellows Kit replacement
remove and install a new bellows kit for a Fridgidaire front-loading washer model ftf2140es0
Need a restart code
Press & hold down the 'options' & 'select' buttons for over 3 seconds. And let me know. These are the buttons, but how long?
FRONT TUB SEAL HOLDING WATER
no fix ..ALL BRANDS have same issue just ck out other web sites best solution ..leave door open as much as possible ..clean out boot with bleach/water solution at least once a month..CHLORINE BLEACH!! and no not the answer you wanted but best answer you'll get and that from experience
Frigidaire Washer HELP
check for a sensor switch located underneath the door , its a safety device to ensure that door is tightly closed . hope it helps
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
