Question about Knowledge Adventure Jump Start Study Helpers Math Booster 6 Levels Over 800 Math Problems for Windows
Combinations Say I Have A and B and a place them in one group which consista of six numbers. For Example: Group A 1.A 2.A 3.A 4.A 5.A 6.A Group B 1.B 2.A 3.A 4.A 5.A 6.A HOW MANY GROUPS OF COMBINATIONS ARE THERE?
Im looking for the total combination for this nuber 13 20 31 36 41 45 permutations i think its called
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
Oct 22, 2014 | Office Equipment & Supplies
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
May 21, 2013 | Cisco 878 GSHDSL Wireless Router for Small...
Does anybody know how many different combinations there are for the numbers 1, 2, 3, 4, 5 and 6?
That depends on how many of those six numbers you take.
If you only take one number, there are six combinations: {1}, {2}, {3}, {4}, {5}, and {6}.
If you take two numbers, there are fifteen combinations: {1,2}, {1,3}, {1,4}, {1,5}, {1,6}, {2,3}, {2,4}, {2,5}, {2,6}, {3,4}, {3,5}, {3,6}, {4,5}, {4,6}, and {5,6}.
If you take three numbers, there are twenty combinations.
If you take four numbers, there are fifteen combinations.
If you take five numbers, there are six combinations.
If you take all six numbers, there is only one combination: {1,2,3,4,5,6}.
In general, if you take 'm' objects out of a set of 'n' objects, the number of combinations is given by n!/[(m!)(n-m)!] where '!' is the factorial operator.
Apr 30, 2013 | Mathsoft Computers & Internet
How many combinations for the numbers 1, 2, 3, 4, 5 and 6?
If you only take one number, there are six combinations.
If you take two numbers, there are fifteen combinations.
If you take all six numbers, there is only one combination.
Apr 30, 2013 | Home Security
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 18, 2010 | Brother IntelliFax-4100e Fax
What is valency of carban
The valency (the number of electrons in the valence shell) of the element carbon is 4.
With most periodic tables of the elements, you can deduce the valency of all of the representative elements [the most common ones in the first 3 rows of the periodic table, and in the first through 8th columns (or groups or families) of the periodic table].
You need only look at the top of each group for the number-letter code (for example, "4A" appears above the group in which carbon resides.
A handy thing about the periodic table is that elements in the same group or family have the same valency. For example, silicon (Si) which is below carbon in the same family as carbon, also has a valency of 4. Another example is that all of the elements in the 1A column (the alkali metals) have the same valency of 1.
Jul 15, 2010 | Scientific Explorer My First Chemistry Kit
KX-T7630 - forward to voice mail
Assuming this is a Panasonic system TDA50, TDA or TDE 100/200 or NCP systems. There are many fwd codes on these systems,done on a per phone basis. To do a fwd all calls (meaning the phone will not ring) dial code *7102+9+number+pound. If you would like to set for call fwd no answer then *7104+9+number+pound. And for call fwd busy no anser the code is *7105+9+number+pound. Keep in mind this is on a per phone basis. If your company is using a ring group to ring the phones this will need to be setup different using the day/night mode and set the night to go to a group that is fwd to your answer service. A phone must be assigned to the group then that phone can set group fwd by dialing *7141+group number+9+phone number+pound. Example if I was using group 3, defualt number 603, to number 555-1234 and group 603 has ext. 102 assign to it then from ext. 102 dial *714160395551234#.
Hope this helps!
Jul 27, 2009 | Panasonic KX-T7630 Corded Phone
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Intercom
Are you referring to page all phones?
you have to put all phones into a ringing group first.
From extension 10 or 11
Feature 00
Left intercom
Left intercom
Press #502
At the group prompt, enter the group number you wish to use (1-4)
At the extension prompt, enter the extension number you wish to add to the group
It will say 1-assigned or 2-not assigned
Press 1 to assign it to the group
Repeat for all extensions
Feature 00 when finished
Now, to page the group, you will press "Intercom *7x (where x is the group number)
Example, Intercom *71 to page group 1
If you wish to put that on a button, you must go to each phone.
At each phone...
Press Feature 00
Press the button you want to program
Press the LEFT intercom button and *71 (for group 1)
Feature 00
Repeat at each phone you want the button on.
Sep 29, 2008 | Lucent PARTNER18 Corded Phone
Knowledge Adventure Jump Start Study Helpers Math Booster 6 Levels Over 800 Math Problems for Windows Logo
Top Knowledge Adventure Video Game Consoles & Games Experts
ray gallant
ray gallant
Brett Duxbury
Brett Duxbury
Are you a Knowledge Adventure Video Game Console and Game Expert? Answer questions, earn points and help others
