Does anyone know how much RAM Ei System 4411 supports?
SOURCE: ei systems 4411 wont power on/mains or battery power
If the fan does not spin, the unit is shutting down to protect the processor. I would have the fan replaced . Do not attempt to use the laptop, it may cause extensive damage if it overheats.
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Ei systems 4411 Battery driver/not charging
first of all check this battary with another same configured laptop of your's.. i guess this problem should be with your battary...
thanks
SOURCE: EI System 4411 Laptop
go to the control panel, internet options, connections tab, then check mark "never dial a connection".
then try to connect.
SOURCE: ei systems laptop memory upgrade?????!!!
1gb ram will speed up your access memory you will notice it a little faster when going from web site to web site but to really speed it up you need a faster prossesor or / and better broadband
SOURCE: how do i restore factory settings on ei system
It does not look like there is a restore partition, you would need the restore CD that came with it...
go HERE
The URL is a little wierd, If it doesnt work, I will repost with the correct one.
