The acrylic repair kit we ordered did not include instructions.
If repairing a fibre glass bath you have to understand that the main bath is fibreglass and resin with a top coat . grind back to fiberglass top and bottom of repair , to reinforce place fibreglass patch mixed with resin under bath = top is jel coat . after repair cut back with wet and dry emery cloth .and polish= easy yes.
SOURCE: small crack in shower tray
Are you talking about the shower pan as in the part of the shower which you stand on? It is possible that you might be able to fiberglass the crack depending on the type of material which the shower pan (tray) is made of. Check with your local Home Depot for a fiberglass kit. Good Luck
SOURCE: Is it possible to get
Well, you aren't going to find another piece that will integrate with your kit, that's for sure. If the long part of the opening is wider than the standard kit size, that's a good thing because it is fixable. I'm guessing your standard kit size is 72 inches instead of the 73 you have now. You just need to pack out the sides by 1/2" each. Assuming that your kit shower walls are integrated with a tub or with a base, then you can use strips of 1/2" plywood or similar to pack out the studs. Likely you'll have greenboard or some other wall surface above the top of the kit walls, so pack out the studs right up to the ceiling--that way the drywall or other surface will be positioned correctly relative to the shower kit walls.
SOURCE: I lost the install instructions
Moen Chrome ExactTemp Vertical Spa:
http://www.moen.com/moen/chrome-exacttemp-r-vertical-spa/_/R-CONSUMER%3ATS270
Product Specifications:
http://www.moen.com/shared/pdf/ts270sp.pdf
Exploded Parts View:
http://www.moen.com/shared/pdf/ts270pt.pdf
Replacement Parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=TS270
Unfortunately the installation Instruction Sheets/Owner's Manual are not posted for the 270 models. Suggest you contact Moen Consumer Support directly to make a request:
http://www.moen.com/consumer-support/contact-us
SOURCE: toilet repair kit the flapper
sorry for delayed response:( what brand is the kit?...did you adjust the pull chain on the flapper so that it is lifting the flapper to high and causing it to get stuck...and/or is that what is happening? is there an adjustment feature on the flapper itself? (look closely it may be something like rotating the flapper)does the flush handle appear to be working correctly? just let me know if i can help:)
