Precor 9.23 Treadmill Logo
E
Edward Posted on Mar 30, 2014
Precor 9.23 Treadmill Inclines Randomly
Problem: The incline goes up on its own (e.g., you can run the treadmill and, while using it, the incline just goes up on its own...and I'm not in 'random mode'). What I've done (per the Precor 9.23 service manual): - initiated the "initialization program" - "calibrated the lift motor" - I checked ohm reading on the potentiometer per the Precor manual. From the board (JK3), the readings are fine (red-to-black = 10, red-to-white plus white-to-black = 10. When I read them from potentiometer itself (the other end of JK3, on the incline motor), the readings are off. - I have not seen any error codes
sunilkchopra
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 38 Answers
  • Posted on Mar 30, 2014
sunilkchopra
Contributor
Level 1:
Night Owl:
Answers
38
Questions
0
Helped
11929
Points
86
Most prob one of sensor / connection gone bad
2answers
Precor 9.45 reset safety switch message wont go away
If you have checked the safety switch on your Precor 9.45 treadmill and everything seems to be intact, and the "reset safety switch" message still won't go away, it's possible that the switch itself is faulty or the console is not receiving the signal from the switch.
You can try cleaning the switch and the area around it, and also check the wires that connect the switch to the console to make sure they are not damaged. If the switch or wires appear to be damaged, they may need to be replaced.
If cleaning and checking the switch and wires doesn't resolve the issue, it's recommended that you contact the manufacturer or a qualified repair technician to further diagnose and fix the problem. They may be able to provide additional troubleshooting steps or suggest other possible solutions.
The incline on our Precor c964i is stuck in a high position (approx. 10% incline). Other than being on a high incline, the treadmill seems to be working fine.
Hi There,
Precor uses a pair of Triacs to drive the lift up and down. These triacs live on the lower board but are driven by the upper console commands via a serial link between the upper and lower. Most precor lift issues we see are related to the lower board but with Precor it could be an upper board or the CPU Chip that resides on the lower board or a failed Triac. Good Luck
Treadmill incline
RUN the software calibration for easy diagnostic, and fix it. Go to THE HOOD cover for the motor and follow the steps or use the owner manual.
God bless you
Unit will not rise incline
Please RUN the software calibration for easy diagnose and troubleshooting. However Lube the elevation motor+shaft+gear+pinion+adjust the small POTENtiometer a little. see the diagram attached and proceedGod bless you
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Upon powering up my precor treadmill goes straight to the highest incline
hi,
Your treadmills motor controlling circuit have some problem. thats why you cant adjust its speed. its running at its high speed because its motor controlling IGBT become shorted. As these potion of your treadmill is a high voltage point, i will recommend you to consult the manufacturer for support.
ok
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
