Question about Sharp XR-10X Multimedia Projector
I am using Sharp multimedia projector XR-32S-L.There are white spots in the screen. What should I do to remove it?
How can I clean the white spots in the screen. Is is due to dust or any other problem?
    New Friend:
  • 4 Answers
White spot in image is comman problem of dmd chip it is fixed in to light engieen with heat sink replacment can possiable by expert
Posted on Jan 19, 2015
  • ashwin rane
    ashwin rane Jan 19, 2015
    white spot in image is comman problem of dmd chip it is fixed in to light engieen with heat sink replacment can possiable by expert
SOURCE:
SOURCE: sharp xr-10s /sharp xr 10sl are they the same unit?
Hey, XR10S and XR10SL is the same. The Lamp is SHP93 if for Replacement.
Posted on Jul 01, 2009
  • 205 Answers
SOURCE: Dropped PROJECTOR and now it won't turn on.
I think this projector uses a color wheel. It's literally a wheel a transparent wheel divided into different pie shaped colored sections.
I am not an expert (or even close) on these proejctors, but I would guess that a fall like this would cause a mechanical problem and the wheel is a mechanical part. If it's not allowed to rotate properly it could be the problem.
If you're in a brave mood you might open it up and see if the wheel is able to spin freely.
Good luck.
Posted on Nov 19, 2007
  • 638 Answers
SOURCE: Sharp Projector XR-10X/XR-10S
YOU CAN SOLVE ALL YOUR PROBLEM THIS IS THE LINK CLICK THIS AND GO PAGE NO 59 AND 60 FOR EACH AND EVERY PROBLEM OF YOUR UNIT GO TO PART 15 OF THIS LINK FOR WARMING UP PROBLEMS
http://www.oconee.k12.sc.us/it/techweb/10_20_E.PDF
IF THIS SOLUTION HELPED YOU ANY WAY RATE THIS AS "FIXYA" .FEEL FREE FOR FURTHER ASSISTANCE. THANK U FOR USING FIXYA.
Posted on Jun 10, 2008
SOURCE: need driver
have you tried looking on sharpusa.com?
they have available software for this projector here:
http://www.sharpusa.com/products/TypeSoftware/0,1086,28,00.html
google is your friend ;o)
Posted on Jun 30, 2008
  • 3 Answers
SOURCE: Cannot remove lamp assembly from Sharp XR-10X projector
Carefully try using a flat head screw driver on the middle plastic piece. make sure it is off...
Or try coming at it from the other side after taking the top of the machine off you can unscrew 3 screws and loosen whatever might be blocking it
Posted on Sep 08, 2009
I have white spots on my image from my projector SHARP XR-55X?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 05, 2013 | SHARP ELECTRONICS CORP PROJECTOR, SHARP...
Spots on image
DMD (Digital Micro Mirror Device) replacement required.
Jan 14, 2013 | Sharp XR-10X Multimedia Projector
BRIGHT SPOTS ON MULTIMEDIA PROJECTOR SCREEN: SHARP XR-32S-L USED FOR 2.5YEARS DISPLAYS MANY BRIGHT SPOTS ON THE SCREEN? IS THE PROBLEM IN THE DMD? SHOULD REPLACE THE DMD OR BUY A NEW ONE? DINESH MUMBA
it is the problam of your dmd chip i think the dmd chip 304 small like a simcard change the chip your problam will be solved 100%
i will show you the chip
Nov 07, 2012 | Sharp XR-32S Projector
Doesn't seem to recognise computer just got blue display on wall tried switching projector on first then computer on first still no luck
Have you tried another computer? have you tried toggling the FN key and your CRT/Icon key at the same time.
May 27, 2010 | Sharp XR-32S Projector
My xr-32x has light spots on the projection
Dust in light path. Cleaning required.
Jul 12, 2009 | Sharp XR-32X Projector
Sharp xr-11xc only displays black & white
Sounds like your connection is bad, check ur connections on ur cables
Oct 25, 2008 | Sharp XR-11XC Multimedia Projector
Sharp XR-1S White vertical stripe
HI there
This could be a costly exercice as this is a common Projector Mainboard failure.
You can either replace the board or have it repaired.
Apr 10, 2008 | Sharp XR-1S Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
314 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
