Mitsubishi WD62527 62 in. LCD HDTV Logo
Posted on Oct 31, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi 62" projection LCD
My TV is 2 years old and is starting to get green spots on the sceen, any clue what could be causing this, or how I can fix it?
  • 1 more comment
  • Anonymous Feb 18, 2008
    I have a green spot on my Mitsubishi 62" LCD TV. What can I do to fix it?
  • tazzmann Apr 11, 2008
    I have a the above mentioned set that has several green spots on the
    screen that do not move or change. On all inputs. As light colors move
    past them, you can see them. On a red screen they look blue. I was told
    by a repair shop it was the light engine and it going to cost $1500.00
    to fix it. I called Mitsubishi and bitched and they said they would
    cover 1/2 the repair cost. I can get a new WD-57733 for $1460.00.
    Should I? Is it worth fixing for $750.00? is it really the light
    engine? I'm vexed and pissed... I didn't get the extended warranty cuz
    it's a frickin Mitsubishi.
  • Anonymous Nov 25, 2008
    I have a Mitsubishi WD52537 with a green spot on it as well. It can be seen unless the screen is black. For the most part, it's not noticeable, but now that I know it is there I always see it. I've removed the front screen and back panel, but was rather daunted by the electronics behind the back panel. I've heard it can be caused by dust so I sprayed some canned air around, but no luck in solving my problem. If anyone knows any specifics on this, i.e. where to focus on finding dust, let me know.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 301 Answers
  • Posted on Mar 29, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
301
Questions
0
Helped
79291
Points
655
Dirt internal to the tv. suggest taking the screen off and removing the small rectangular panel in the middle and spraying off LCD panels located under metal fins. this should fix distortion.......for now.
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
1helpful
2answers
KEEPS SHUTTING OFF
What type or TV is it DLP , LCD, Plasma?
DLP -----> LAMP--------->go to this 2 sites
http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi%20WD-62525%2062
http://www.discounttvlamps.com/mitsubishi-tv-lamps-s/20.htm
PLASMA------->Digital boar or On switch it depends ... can you go on the Display Menu and it looks goo?
do you see any spots?
LCD-------------> You need DMD Bord
good luck tell me more so we can figure it out!
3answers
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Green spots
Good Day;
It sounds like the TV has foreign objects on the tubes, lenses or inner-screen, such as dust or bugs.l Remove screen from the front and observe.
If it were a TV problem the spots would be near the center of the picture.
Good Luck.
2answers
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
Lcd shadow
you need to call acer you have a bad lcd sceen. i juct di one the sceen was fault.
3helpful
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
2answers
My mitsubishi dlp hd tv has color bleed and everything is purple and green after set warms up. What causes this to happen? What does it take to fix this problem. the set is only 15 months old.
This set has the problem of sucking up dust and scuzzing up the light engine, this causes purple and green spots, A good tech can disassemble the light engine and clean it, the cheap ones will change the light engine
TV has line down the middle
Remove the front sceen and check for a cob web acrossone of the px tubes, is one possible cause of your problem.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
