Vehicle Parts & Accessories Logo
A
Anonymous Posted on Mar 30, 2014
Battery draining Battery drains after a day
Jensen Beach Speed Shop
Level 3:
Master:
  • Master 710 Answers
  • Posted on Sep 07, 2014
Master
Level 3:
Master:
Answers
710
Questions
Helped
141106
Points
7635
1. Make sure the battery is good.
2. If the battery is good check for a amperage draw.
3. Isolate where the draw is coming from and make the necessary repairs.
Something is draining the battery on our 2002 bmw z3.the battery and alternator checks out good,what is draining the battery??
HELP 2000 Z3 Battery Drain - Bimmerfest - BMW Forums
www.bimmerfest.com > ... > Z Series > E36/7 Z3 (1996-2002)
Feb 18, 2007 - 7 posts - ‎6 authors
HELP 2000 Z3 Battery Drain E36/7 Z3 (1996-2002) ... Something is draining the battery. ... Posts: 55. Mein Auto: 2000 BMW Z3 2.8 Roadster. z3 1.9 battery drain (fuse 31)
Apr 9, 2013
Intermittent car battery drain problem NEED HELP
Jan 29, 2013
Mysterious Battery Drain
Feb 23, 2008
Battery drain....after 2 days sitting dead...
Mar 28, 2006
More results from www.bimmerfest.com
Jan 18, 2016 • 2002 BMW Z3
2answers
New battery keeps draining. Don't know what is going on. It's a 2001 ford explorer sport 4.0 l.
Starter and alternator are the most likely culprits(one day). Interior lights and radio will also cause this. But usually takes a couple days to drain the battery.
1helpful
Mitsubishi Diamante 2002 - slow battery drain when not running.
This problem may be a drain or a bad battery or alternator.
The first thing to do before going on trying to find the system that is draining the battery would be to have the battery tested and charging system tested.
A weak battery will seem ok after the car is jumped or will barely start the car and the alternator will charge it even though the alternator is overworking due to weak battery and during the day or when car does not sit long it will seem ok. then when car sits overnight or a few days battery will weaken on its own, making it look like a drain,
so first step is battery test and alternator/charging system test.
1helpful
2answers
99 toyota corolla drains battery. After parking the car for a few days, it won't start...just a clicking noise. I thought my battery was bad and got it tested at autozone...the guys told me it was not...
You may have a parasitic drain on the battery.
Check the voltage on your fuses after you turn it off. Wait 5 minutes before doing so.
Hook up an Amp meter in series with the battery and see what the current draw is. If it is more than 250 milliamps you have a parasitic drain.
Battery drains if not used for 2 days.
heater resistor's cause battery drains and air con operate incorrectly.
The battery in my car keeps draining. takes about a day or so to drain. it's not the alternator
Sometimes the battery itself is the problem. The quality and age plays a big role. Best way to test is to disconnect the battery cables from the battery after your done using the car. Then a day or so, hook the battery back up and then see if the problem still occurs.
If the battery drained, you'll know the battery itself is the problem.
2helpful
2answers
Battery on mercedes A140 drains. I drove the car
aftermarket stereo? dome lights? car alarm? Use a multimeter and see what fuse has power draw when car is off.
2helpful
1998 Corvette drains the battery in less than 2 days.
No, corrosion will not cause a battery to drain, even if the corrosion is on the terminals. Several factors can cause battery drain, I would first have the battery tested to see if the battery it self is not bad. If the battery is good, then the most common is a short. All most all new cars have a certain amount of drain,(measured in milivolts) this drain is for clocks and computer memory's, and it would take several days of a vehicle sitting for the battery to be drained. Don't immediately assume you have a problem if you see 2-6 milivolts of drain on a battery with the key out, now if your battery is being drained after being parked over night, you have a problem. The easiest way to pin down the problem short is to disconnect your positive battery cable from the battery, take a 12 volt test light and clamp one end to the positive cable, and hold the probe to the positive post. Now if you have a short the light will come on. Have someone help you by pulling the fuses one at a time. If when a fuse is pulled the light goes out you have isolated the short to that system. If you pulled all the fuses and the light never went out try disconnecting all the wires from the alternator, 9 times outta 10 do this will let you know where your short is. If the system is not critical like power locks some people just leave the fuse out.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
