Water Heaters Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I re-pressurise the boiler via the temporary filling loop
After bleeding the air from a radiator the pressure in the boiler dropped to zero, on the printed label on the boiler it states that the pressure must be between 1 and 2 bar, if it falls below 1 bar the heating must be re-pressurised via the temporary filling loop
Anonymous
Level 2:
  • Expert 332 Answers
  • Posted on Jun 21, 2009
Anonymous
Expert
Level 2:
Answers
332
Questions
0
Helped
222756
Points
689
You may need to hook a hose to the drain and to a spigot depending on your water pressure in your home and back feed the unit to desired pressur,, does t have an auto matic feed valve or just a shut off valve,,
Worcester 30cdi boiler showing no pressure fires up and then cuts out
Re pressurise via filling loop,if boiler continues to loose pressure replace the expansion vessel.
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
1helpful
Low pressure on recently serviced Vokera 14/48se.
Identify the cold feed to the boiler, then look for a tap/service valve which when turned lets water into the boiler via a fill loop to pressurise it. 1-1.5 bar is ok
ju
2helpful
The pressure drops very slowly over a month then needs topping uo from the filling loop to 1.5 bar. when the heating is on it goes upto 3 bar. the pipe outside is slightly damp. it was fine during the...
Sounds like the expansion vessel in the boiler has lost pressure or is faulty. If you have a tyre pressure gauge, locate the expansion vessl and check the pressure via the schraeder valve. It should be around 1.5 bar. If there is no pressure you can re pressurise it with a bicycle pump. Should it not pressurise then you will need a new one. The pressure relief pipework outside is damp because the system is over pressurising at relieving pressure at 3 bar. This obviously causes a system pressure drop. You can install a pressure vesel into the heating return pipework should accessing the boiler be difficult.
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
1helpful
2answers
Vokera linea 28 boiler. I am continuously having to re-pressurise the loop (about twice weekly) also i keep getting a code 3 error appear which i know is a fan flue problem i have reset the boiler. The...
I have a similar problem with this boiler. When CH on, boiler overpressurises, (check relief valve outlet) You will then lose water from the CH loop and will have to repressurise when the CH loop cools. The problem is most likely caused by a loss of air from the expansion tank, which will need re-charged. This is not a big job as it has a standard tyre type valve connection but needs an accurate pressure gauge. Probably best left for plumber.
2helpful
2answers
Worcester bosch greenstar 25Si?30Si pressure gauge showing high
a couple of things , is your filling loop disconected ? , and are all your radiators blead from air, have you got a high point where the air can get stuck in system say pipes going into roof etc you may need to fit a air release valve in line at highest point to remove the air from system , your boiler should be around 1.5 bar running preasure average setting . if you are constanly filling with water you could be exceeding the pressure valve limet which releases pressure from system this could be faulty ?
4helpful
How to re pressurisecentral heating system
Hi tiger650,
I'm Harvey the Master Plumber.
Your problem is: The Alpha SY24 boiler has stopped working. The pressure gauge has dropped, you need to know how to re pressurise the system once the radiators have been bled
Every hydronic heating system is required to have a presure regulator. Most guys call it a feeder valve. Every one I've installed or worked on had one. It's job is to keep the water pressure constant by adding water when you release some air without over filling the system. Sounds like it's not working. Some types can be serviced, others cannont so you may have to replace it. If you're not sure what to do it might be prudent to check the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
