Usually the sink connection is not an overflow, it is the main drain
from the dishwasher. It is more likely your s-bend is blocked under the
sink- try putting a bucket under it and unscrewing the u-shaped piece
and cleaning out (remember don't wash it in that sink while the pipe is
off)
Beneath
some dishwashers, there's a timer-activated drain solenoid (an
electro-magnetic coil) that opens a drain valve, to drain the wash
water through a hose and out to the house's plumbing waste system.
Thermostat
Dishwashers
have one or more small, cylindrical thermostats. These are a bit larger
in diameter than a dime and have two or more wires attached to them.
They protect the dishwasher, dishes, and humans by turning off the
heating element that heats the water or the air in the dishwasher when
it has reached its pre-set temperature. The thermostat automatically
re-sets when the temperature falls to a lower level.
Soil sensors
Many
of the more-recent dishwashers use multi-component soil sensors, which
continually monitor the wash water during the wash cycle. These sensors
help the dishwasher to wash for the amount of time that is appropriate
for how dirty the dishes are, rather than for a pre-set period. When
the water becomes clear enough, the sensor signals the timer to
continue with the next cycle.
Door switch
Dishwashers
have a door (or door interlock) switch that--if properly
functioning--shuts off the dishwasher when the door is open.
Drying fan
Some
dishwashers use a small fan to blow air (or heated air) into the
dishwasher to dry the dishes faster. If your machine has a drying fan,
it's beneath the dishwasher, usually in the back right corner.
you have something in the sump there's a screen on the right side of
the spray arm with 2 screws remove them and take screen off use your
fingers to probe the cavity be careful it could be glass.
If it does not correct the problem
!.You may have an electric pump . and it could be pump without water . so i would say a bad pump.
moter problem
This is either a bad timer or a bad heat sensor. On most cycles that
call for the water to be heated it will pause the timer and continue
washing/heating until the sensor is satisfied the water is hot enough.
Try selecting a quick, delicate, or china cycle without heated rinse or
dry. If it works this way the timer is fine but the sensor is bad.
Sometimes cold water to the machine will cause this problem because the
machine is not capable of totallly heating cold water. It is only
designed to boost the temp. Make sure you run hot water at the sink
before you start the machine.
change the motor
There is a pump motor underneath with an impeller that is most likely
stuck. You will need to turn the impeller until it breaks loose if it
is stuck. This is a common problem with GE dishwashers and I recommend
that you run it at least once or twice a week to avoid this problem in
the future, even if you have to run it empty.
If you remove the front panel at the bottom and look underneath, there
is a motor staring at you. The motor has blades that look like wings of
a fan. If you take a screw driver and try to rotate the blades, you
will feel that they dont move freely. This is what someone said, the
impeller (blades) are stuck. You need to keep rotating the blades until
they get free rotational motion. I had the exact same problem and I was
able to fix it this way.
Is the door open or unlatched?
Make sure the door is completely closed and latched.
Is the selected cycle incomplete?
To drain while the dishwasher is running, press the Start/Cancel pad once. The dishwasher will drain, and then shut off. To drain while the dishwasher is not running a selected cycle, make sure the door is completely closed and latched, and then press the Start/Cancel pad twice. The dishwasher will drain, and then shut off.
Is there a new garbage disposal?
Make sure the knockout plug is removed in the new disposal. For many dishwashers, the drain hose is connected to the disposal. The knockout plug must be removed from inside the food waste disposer inlet.
Is the drain system blocked?
Run the disposer to clear the drain system.
Do you have an air gap at your sink?
Check to see if the air gap is blocked by foreign material. To clean the drain air gap, follow the cleaning instructions provided by the manufacturer. With most types, you lift off the chrome cover, unscrew the plastic cap, and then check for any soil buildup. Clean if necessary.
Is there a loop in the drain hose less than 20" above the floor?
Make sure the drain hose is looped so that it touches the underside of the counter before connecting to the sink drain or disposer.
Is there a kink in the drain hose?
Replace a kinked drain hose.
Did you reuse an existing drain hose?
Make sure to use the new drain hose that came with the dishwasher.
Is the sink drain clogged?
If the sink is not draining well, a plumber may need to be contacted. Most dishwashers connect to the sink drain. If the sink drain is clogged, the dishwasher can't pump out water.
That page will not open :-(
We said "When it calls for a drain cycle it sounds like the MOTOR TRIES TO START for half a second and then the display blinks and there is a click."
