Question about Panasonic Televison & Video
Panasonic TC-P46-C2 one red blink
I have a Panasonic TC-P46-C2 that when powered on I hear the relays click but the TV doesn't power on. The LED gives a single blink code. What does that indicate the system sees as a fault?
    Top Expert:
  • Panasonic Master
  • 76,140 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 30, 2014
  • marc ashton
    marc ashton Mar 30, 2014
    On that site all the info for my model TV doesn't give a description of what one blink indicates. It does on the C1 version which was the prior year's model, can I assume it is the same?
SOURCE:
  • 6 Answers
SOURCE: Relays click. That's about it
try unhooking the wires coming off the power board you should be able to unhook every thing except the switch wire and se plug if the green lights stay on and the red don't come on then you have something loading down your power supply if it still shuts down you need a new power supply
Posted on Mar 20, 2008
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
  • 12 Answers
SOURCE: LOST POWER ON A VIERA 42 INCH PANASONIC PLASMA TV
Take the unit in to be serviced.
Posted on Jan 21, 2009
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
  • 43 Answers
SOURCE: Samsung LCD 40" While LInes, Clicking Noise, Red light blinks
Your LCD has gone bad or their is a high voltage problem that powers the LCD. Usually a inverter board.
Posted on Jul 04, 2009
Panasonic TV, Model TC-P505U50
Not sure if it is Plasma or LCD/LED model.
Check out the codes below
Panasonic TV Blink Codes for All Panasonic Models Brainchamber Blog
You need to verify the Power board for defective capacitors. You can replace the defective Capacitors yourself if you are a DIY person or replace the entire board if you can obtain the part.
Aug 01, 2016 | Panasonic Television Mainboard, TV Model...
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Panasonic Viera TC-37LZ85 powers on with a solid red light that does not blink, the screen slightly illuminates but no picture. Blown fuse?
T'Con board fault. In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 10, 2015 | Panasonic Viera TC-37LZ85 LCD TV
Panasonic Viera tc-p60st30 tv will not turn on. No red blinking light. Relay clicks every 10 seconds.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 14, 2013 | Panasonic Viera Plasma TV TC-P60ST30
I turned on power and red light is blinking but tv does not come on - red light just blinking no power/picture Panasonic TC-54PS14
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Panasonic TC-54PS14 54" HDTV Plasma TV
Televison & Video Logo
148 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
