Laguna water garden pump just quit working
Possible causes: Electrical or Mechanical. For Electrical - Check to make sure power is coming to the outlet/cord it is plugged into. If there is a GFCI on the circuit, make sure it is reset.
Mechanical: If something got sucked into the pump it may have caused the impeller to stop and/or the pump to overheat. Some models have an thermal override that will shut the pump off if it overheats. If it is a magnetic drive pump, the impeller can probably be saved, if it is a direct drive, it may have gotten damaged by the jam. Unplug the pump and carefully disassemble the portion where the water goes in to determine if something got sucked into the impeller mechanism.
