do this :Open the case ,take the belt out and clean it, lube the gears with oil and all is well.and replace the Belt, if necessary. See ifthe motor is functioning or replace/repair.
Merry Christmas
Check if your DR-40 has auto-rec turned on. If so, it will only record once a certain input level is present, and will stop if the input goes below that level. The recorder will turn back in when that level is exceeded again.
Secure the audio/video connection cables that attach the source device you are trying to record from. Try this step if you do not see a picture when trying to record from a source device onto the Device. After unplugging the cable and checking for any damage, plug the cables back and attempt to record the content to see if this resolved the problem.
Secure the power cable that attaches the device to an electrical source if the unit will not power on or if it intermittently loses power. If you think a malfunctioning surge protector may be at fault, you can 'bypass' the surge protector by plugging the device into an electrical outlet. Replace any surge protectors that appear to be malfunctioning and have an electrician examine any outlets that appear to be "dead."
Insert the disc that you would like to record
Press the "Edit Menu" button on the remote control while playing the disc or while playback is stopped.
Use the up and down arrows to select "DVD-Video Finalizing" in the on-screen menu, then press "Enter."
Under "Menu Create" select "None," then under "After play final title" select "Stop." Select "Next" to move to the next screen.
Select "Writing" in the lower right of the screen.
Select "Yes" or "No" to tell the machine if you want it to power down when finalizing is complete. Finalizing will then begin and a progress bar will appear.
Contact your electronics dealer or the Toshiba service department if the disc still does not finalize.
Check pages 44 and 45 of the installation guide (not the owner's manual.) It will tell you how to change the recorder & the remote from DR 1 to DR 2 or DR 3. To change the remote you hold the * button plus 1,2 or 3 to change the remote.
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
