Toys Logo
P
Peter Walters Posted on Mar 29, 2014
International b 414 tractor
Hi dose any one no how to split the tractor under the derv tank to get to the slider gear on the hi and low in the transmisson box it splits about 1.1/2 inches then stops pleas help.
5 Related Answers
Anonymous
  • 32 Answers
  • Posted on Jul 23, 2009
SOURCE: Hi, Ineed 5 speed Peerless transmisson for a troy
if you are handy you can take it a part and replace the parts inside. or drive around the country and find a mower with no engine for cheap. go to the Tecumseh web site to see witch trans are the same most bolt up
Anonymous
  • 273 Answers
  • Posted on Aug 12, 2009
SOURCE: Clutch Malfunction and Adjustment
check clutch cable it could be either stretched or snapped if not you need a new clutch
Anonymous
  • Posted on Sep 23, 2009
SOURCE: Feber Exlorer Jeep Wheel Replacement
Call the Feber customer helpline on 0844 5610008. They quoted me a price of £30.54 inc P&p from Spain!
Anonymous
  • 81 Answers
  • Posted on Jun 28, 2010
SOURCE: Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
collmann3
  • 18 Answers
  • Posted on Mar 20, 2011
SOURCE: hi, i have an 806 international tractor. it will
linkage is worn. remove deck plate and check shaft going through range cover to see if ts worn.also check arm on verticle shaft to see if keyway is worn. these parts are availeable from your local caseih dealer
2answers
John Deere 950 tractor hi low arm install
If you mean the lever itself (2), see attachment, then no, it is held in place with a roll pin (3). So it should not require access inside the case.
2answers
Have a Massey Ferguson 2615 that's stuck in foward gear and won't come out of gear. Tractor does stop when clutch depressed and hi/low still works. Need Help
Did you ever figure out what the problem was with your 2615 Massey Ferguson tractor and why it was stuck in gear. I have one that is doing the same thing
Jan 30, 2016 • Toys
My 755 is stuck in low gear
If the (High,Low) engagement handle is loose and can move (Low to High) and the tractor stays in low, look for external linkage for missing or loose parts. If the engagement handle is tight and will not come out of low position it sound like there is an internal problem. Look for any external obstructions on the linkage that would keep it from moving. If not the problem could be an internal problem. Possible internal problems could be shifting fork,shifting shaft, or shifting linkage.
No high gears in my 3010 John Deere tractor
You may have a keyway broken in the hi/low selector
Apr 21, 2014 • Garden
Shermon shifterin ford 8n
http://www.yesterdaystractors.com/atrp/specs/ford.htm
The above link is an excellent site for help. Can you see if the shaft is turning when you try to shift the Sherman Hi/Lo transmission.?
The Sherman units are installed inside the housing between the engine and Ford transmission and I believe you would have to "split" the tractor to access actual Sherman unit. It sounds like either the Hi/lo lever is slipping on the shaft or has broken internally....good luck. Try doing a search for ( Sherman transmission Ford 8n tractor help) there are a lot of Old timer experts out there and this was a very popular addition to the 8n's
2helpful
Hi, i have an 806 international tractor. it will shift into hi ,lo, and reverse but i have to go from neutral to hi several times before it will go into hi gear and this also happens in reverse. i have no...
3helpful
How to use the 4x4
well, if you are sitting still it is recommended you put vehicle in neutral and select 4x4 indicator to desired posistion..... 4 high...4 low...or 2high (auto) when you select 4 low the top speed is not to exceed 25 mph. It is a very low gear for crawling or pulling. At any time you need 4 low gear you must stop trk, shift to neutral and select 4 low. The same procedure is done to change from 4 low to 4 hi or 2 hi. if not done this way internal trans, transfer case or driveline failure will occure. At any time you may shift 4x4 selector from (auto) or 2 hi to 4 hi, and 4 hi to 2 hi or( auto).****** But note, do not make shifts while tires are spinning or under power (acceleration)******* While driving you can make shifts at any speed between 2 hi (auto) and 4 hi and back to 2 hi. release throttle a little and select. you do not have to take foot off throttle all the way! just enough that truck is not under a power, load acceleration. If tires are spinning or you are on the gas and you select gears from 2 & 4 high the posibilities of severe damage can result. Also note that 4x4 is not recommended on dry pavement. When 4x4 is being used also take care as to the handling and the steering characteristics change, On tight turns the front wheels will bind and possibly **** a little. If you have never had a 4x4 before, obey what i have told you untill you get the experiance and you will be fine. HAPPY TRAILS.... AND A LITTLE 4X4 FUN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
5helpful
2answers
Ford 8N has a broken tooth/teeth on ring gear. How
Hi..my name is Keith..and i restore 9N's,2N's and 8N's....and to replace the ring gear..you split it there at the back of the engine..and its kind of a big job..so i would check the starter 1st..to make sure its not a starter problem..i hope this helps..if not please write back..i love tractor problems
Top Ertl Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Ertl Toy Expert? Answer questions, earn points and help others
