Lenovo IdeaPad Yoga 13 Logo
S
Sandra Kipnes Posted on Mar 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keyboard lock My keyboard stops working as if I am in tablet mode when I am not. Is there a manual way to set it to the physical keyboard? Just started - was working for 7 months fine.
Tom Burke
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 81 Answers
  • Posted on Apr 13, 2014
Tom Burke
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
81
Questions
Helped
17295
Points
100
I do not believe there is. It is dependent on a proximity switch in the display. You should contact lenovo for a factory authorized repair before your warranty expires.
  • Tom Burke
    Tom Burke Apr 13, 2014
    I meant to type sensor not switch. The sensor disables the keyboard. This what needs to be changed by an on site technician or at an authorized repair shop
Onn 2in1 tablet 100002435 shuts off when tablet is put in keyboard dock
How to Enable Physical Keyboard When Laptop Switches to Tablet Mode
  1. Go to the Tablet Mode tab under Settings -> System.
  2. Toggle the "make Windows more touch friendly" option on or off.
  3. Select whether the device switches modes automatically prompts you or never switches.
Where is the enter key on Tablet 4gx Enhance
The location of the enter key on a Tablet 4gx Enhance may vary depending on the specific model and manufacturer. Some tablets have a physical enter key on the keyboard, while others may have a virtual enter key on the on-screen keyboard.
You can check the manual of your tablet or do a quick search online to find the specific location of the enter key on your device.
If your tablet does not have a physical keyboard, you can find the enter key on the on-screen keyboard. It's usually located on the right side of the keyboard, next to the spacebar.
Cant switch from tablet to keyboard
In win10 settings is a switch you move from tablet mode to keyboard
go to settings then systems then down to the tablet mode and pick yer poison
Keyboard will not work
Dawn,
IF your tablet and keyboard work with "Bluetooth" then check under you tablets settings page (look for Bluetooth) it may have been turned off.
IF your tablet/keyboard does not used Bluetooth, check the battery in the keyboard, It may have been depleted...
Does the keyboard have an OFF/ON switch, that my also be your issue.
Hope this helps.
Topbarhive
IPad stuck on headphone mode
Try power down iPad and see if it reset to default setting if not go to setting icon and go through your setting options.
1helpful
How to unpair bluetooth keyboard from tablet
First off go to setting an then Bluetooth. I'd first try activating it there. If it still fails to work you can stop it and also delete it from that settings screen.
3helpful
2answers
Ever since I downloaded Apple's latest iPad update my orientation lock has become a mute lock and I can't stop my orientation from moving. Any ideas?
In order to use orientation lock with the new update:
  1. Double-click the iPad's home button, bringing up the multitasking menu with all programs you are currently running.
  2. Swipe your finger to the left while in the multitasking area.
  3. The orientation lock is now controlled through a software feature rather than the physical mute button.
  4. Tap the orientation lock icon (circular arrow furthest to the left) to engage it.
  5. In this menu you can also quickly change brightness settings and music controls.
A new feature rumored in iOS 4.3 (the next iOS iteration) will allow for the iPad's user to set whether the physical button controls orientation, or act as a mute switch.
My keyboard stopped working on my laptop how do i fix it
shut down the notebook. Remove the battery for a couple of seconds and replace it. It works for me every time.
The keyboard locks up on mine when I turn the notebook on while in tablet mode. I mean the cover is closed with the screen facing out.
3helpful
2answers
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
2answers
My medion 95924 keyboard is locked. I am unabe to
Does the keyboard work in Dos mode or when you boot up goto set up and see if you can use keyboard to adjust settings
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
