Furniture Logo
Russ Posted on Mar 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Joints of bedroom dresser drawers have separated and need re-glued
Some of the joints of the drawers have become separated; the sides of the drawers are wood, and the bottoms are like a strong cardboard. There's still a bead of the original glue by the joints; does this need to be removed before regluing and clamping? I hope not, because this may mean more effort than it's worth. Any recommendations on what type of glue to use? It takes considerable force to rejoin the pieces, so the glue must be strong.
alex shalvin
Level 1:
Habit-Forming:
New Friend:
  • Contributor 2 Answers
  • Posted on May 08, 2019
alex shalvin
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
Questions
0
Helped
2821
Points
12
Hi Russ! Check out stylish and sturdy bedside tables and dressing tables for sale with exclusive deals. Lasting Durability assured. https://furnitureoffers.com.au/
Jim DuBreck
Level 3:
  • Master 578 Answers
  • Posted on Mar 29, 2014
Jim DuBreck
Master
Level 3:
Answers
578
Questions
Helped
252830
Points
1695
Any high quality wood glue from HD or Lowes will do it. If you can close the gaps without removing the old hard glue...then go for it. Clamp well and leave overnight.
Need to re-glue wooden/cardboard joints on dresser drawers
liquid nails is the adhesive and use clamps until it is dry
Drawers coming apart
I answered this once but I don't see my response here, so here goes...Get some Elmer's exterior wood glue. It is waterproof, easy to use and it is cheap. I'd suggest at least sanding the joints, but I've left the old glue before, since it didn't interfere with the joint refitting tightly.
Mar 29, 2014 • Furniture
Joints in dresser drawer need re-glued
Elmer's exterior wood glue is the favorite, I don't recommend plain Elmer's white glue because it isn't waterproof. You should at least sand down where the joints meet. Removing the glue is best for a longer term repair, but I admit I've taken the short route a few times. Many people think epoxy or superglue will work, and it might for a few days. Wood glue is cheaper. If you can't clamp your joint then put it on it's side and stack about 25 pounds of stuff on top of it. Books work well, or something that weighs about as much as a car battery.
Need to glue some joints in the drawers of my wooden/cardboard dresser
yes it would need to be removed ,,, scrape of the excess and use a low grit sand paper to make it quicker ........ usually how wood joints work is the glue makes the male joint expand inthe female joint making a very strong bond . for this you need to make sure all old glue is removed so the wood is exposed again so the glue can be absorbed into the wood ... pva glue works well , ask at your diy store they will be able to suggest a good adhesive. if you dont want to clean it maybe a modern adhesive like no nails may work too .... good luck
1helpful
Can't remove drawers from Hayworth mirrored 4 drawer dresser
I'm not sure about the dresser drawers, but for the night stands and the armoire, pull the drawers all the way out. Feel under the drawer (towards the middle back), and there should be a plastic tab. Push the tab down toward the floor and pull the drawer at the same time. It should come right out.
Drawer will not close on child craft 3 drawer dresser
Make sure the drawer is either nailed or glued together properly...also try a little lubrication on the sides od the drawer to make it slide in easier.
4answers
What is the difference between a dresser and Armoire?
The biggest and most obvious differencesbetween the two items of furniture are that a dresser has a mirror, it islonger than it is tall and dressers only consists of 2 draws.. An Armoire istaller and has space to hang clothes.
May 29, 2012 • Furniture
2answers
What is the difference between a chest of drawers and a dresser?
Dressers are usually longer than chests ofdrawers and have 2 drawers that are long and not very deep. Dressers areusually shorter to allow room for a mirror to be places on top of it. Chests ofDrawers are usually taller and have multiple drawers usually smaller in lengthbut deeper and is more used for storage.
2answers
What is a dresser?
A dresser is an item of furniture thatcomprises on multiple drawers and it is usually found in the bedroom. It isused for storing smaller items such as jewelry and underwear.
Top Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Furniture Expert? Answer questions, earn points and help others
