Washing Machines Logo
D
Don Bielli Posted on Mar 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What dsoes E72 mean?
Keypad displays E72 call service
Melissa Martin
Level 3:
Master:
  • Frigidaire Master 753 Answers
  • Posted on Mar 30, 2014
Melissa Martin
Frigidaire Master
Level 3:
Master:
Answers
753
Questions
0
Helped
196296
Points
1330
Does it say in the owners manual because I see not 72 for an error code in the tech sheet
Frigidaire front load dryer, displays E72 call service, what does this mean?
Hi Don, this is AP!
I understand you are receiving an error code of E72 on your Frigidaire dryer. Without knowing the model number specifically I can tell you the general explanation for an E72 code is an outlet control thermistor short circuit. The recommended solution is to check the resistance of the outlet control thermistor, and check wiring for a short circuit across the thermistor connections. Resistance should be between 4.9K ohms and 6.2K ohms at room temperature (68-77F or 20-25C). You may possibly need to replace the outlet control thermistor and/or wiring and retest.
However, this is not a typical DIY project. I would recommend reaching out to an experienced appliance technician just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
Best of luck,
E72
Hello Don, this is Z! Thank you for your post!
I see that your Frigidaire washer is displaying error E72. Have you recently moved your washer to a different location or have the hoses been removed? If so, please verify that the hoses are connected to the correct valve. Otherwise, I would suggest contacting a professional to accurately diagnose your washer since it may possibly be experiencing a communication problem with the control board of faulty valve(s). Hope this helps!
Can i operate my e72 from the computer because my keypad is not functioning
Yes you can, Use Nokia PC Suite for SMS and for calling u can use Dialer .
Nokia e72-1 white display
Hope it's the LCD Display problem if not the pata that connect the board and the LCD (display or screen)
Please try by replacing the (LCD)screen.
Note: If you can't fixed it by yourself then please refer to the nearest mobile service centre. (Cos' the LCD price is high)
Thanks for using FixYa!
2answers
My e72 only shows a blank white screen everytime i turn it on.
Sir.Display problem orSoftware damage pls condact service center
1helpful
4answers
How to get unloced nokia e72
You can get the UNLOCK CODE at here
Simpleunlocking.com
and get the Phone Unlocked from Network lock,You can follow the instructions below and unlock it step by step...
Nokia E72 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia E72 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E72 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E72 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E72.
3 - Compose #pw+CODE+1#.
4 - The Nokia E72 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E72 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E72
1helpful
How can i type _ in my nokia e72 mobile
hi ,in your mobile keypad you will find bluetooth sym key just press that in that you will find _ symbol.
1helpful
My nokia e72 volume control doe not work, also
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
