Question about Samsung RS2556 Side by Side Refrigerator
Samsung double door refrigerator/freezer is not holding the tempature in the refrigerator. When you attempt to reset the temperature and press "power cool" nothing... temp remains around 56 The freezer temperature is holding fine.
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
SOURCE:
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 14, 2017 | Samsung Refrigerators
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Sep 30, 2016 | Samsung Refrigerators
I just replaced the control board and now it won't reset
Hi try this. 1 press & hold the door alarm keypad. .2 press & hold freezer temperature down keyboard within 3 seconds. .3 release the door alarm alarm keypad and wait 3 seconds. 4.the control will DISPLAY PE to indicate the programming mode 5.entry is confirmed by pressing the freezer temperature down keypad once more. .6 the control will display the current program CODE this program should be validated with the program CODE printed on the unit serieal plate ..NOTE.IF THE PROGRAM code is correct the programming mode is excited by pressing door alarm keypad for 3 seconds. .7.press the refrigerator temperature up keypad or refrigerator down keypad to change the digit value with each key press. 8,. the decimal point indicates the selected digit press the freezer temperature Up keypad to select next digit. . 9.. Once the desired program code is entered press & hold the freezer temperature down keypad until the program CODE begins flashing indicating it has been saved.Note.if u attempt to enter an invalid code the control will not save the new code ...but will beep ,,(the unit will not run with a program code of 0000 ,). Once the program CODE has been saved the programming mode is excited by pressing any key.if the new code is incorrect this process should be repeated.the programming mode can be excited at any time by pressing door alarm key for 3 seconds or will exit if unattended for 4 minutes..good luck
Jun 16, 2016 | Maytag Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
Chimes constantly. How do you turn them off?
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung RF263AEBP Refrigeration :...
My samsung frige, french doors keeo ringing
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 19, 2015 | Samsung Refrigerators
How do I get my refrigerator to stop beeping
Sep 10, 2014 | Samsung RF4267HARS Stainless Steel French...
Reading on door OF
Teresa, The fridge is in a retailers demo mode and here is what you do to reset it to normal operation:
Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
  • At the top of the door frame: Simultaneously press and hold the "Power Freeze" and "Freezer" buttons until you hear a distinctively different chime sound and the temperatures for the fridge and freezer are both displayed.
  • Note: If the temperature is displayed, but then "OF OF" reappears a few seconds later, Cooling Off mode was not disabled. Repeat the actions above, and be sure to press and hold the buttons at the exact same time until the distinctive chime sound is heard and both temperatures are displayed.
Apr 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
Personality code
osborne, you can try this procedure.
PROGRAMMING MODE: (FOR PROGRAMMING A NEW CONTROL)
NOTE:
The Program Code is located on the Serial Plate on this unit after the word Code.
1. Open the Fresh Food door and press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
DIAGNOSTIC TESTS
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program Code. This value should be validated with the
Program Code printed on the unit serial plate.
NOTE: If the Program Code is correct, the Programming Mode is exited by closing the Refrigerator
door(s).
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad
to select the next digit.
9. Once the desired Program Code is entered, press and hold the Freezer Temperature Down
Keypad until the Program Code begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program Code the control will not save the new code,
but will beep. (The unit will NOT run with a Program Code of 0000).Once the Program Code
has been saved, the Programming Mode is exited by closing the Refrigerator door(s). If the new
code is incorrect this process should be repeated after closing the Refrigerator door(s).
The Programming mode can be exited at any time by closing the Refrigerator Door(s) or
will exit if unattended for four minutes.
i hope i was able to fix your problem.
Jul 02, 2008 | Maytag MFD2560HES Bottom Freezer French...
My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Jun 22, 2008 | Samsung RF265AA Bottom Freezer French Door...
Samsung RS2556 Side by Side Refrigerator Logo
1,238 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
