Your iPhone should have come with a usb cord. First does your computer have a usb port? If not you will not be able to connect your phone to the computer. If you do have a usb port, plug in the smaller side of the cord and the larger end plugs into the phone. It is a plug and play and should automatically start adding a driver.
insert the disc that comes with the phone and run it. this should install all necessary drivers for you but if you dont have it, you can go online and search for the drivers.
download the software from the manufacturer's website and the data cable between your phone and the pc or else if you use bluetooth if it has one( both your pc and mobile should be enable for this). Then follow the instruction wizard from your software which you downloaded and there you go!! Bingo you have a connection.
first chek in usb setting ,if u want to connect Memory card,it shopuld be "memory card".i think u have not installed Drivers for ur phone....just put the Moto phone tool CD in ROM,& then connect ur phone through USB,,& select driver browse folder to CD ROM...it will automatically find the drivers from CD..
To install themes on your l7 you will first have to download skinman and p2k drivers try the latest one (you can search for these softwares in google) In your phone change the default USB settings as data & fax connection then connect your phone to a usb port to which you had never conected your phone before then you will get a message that a new hardware is found select to "install now" then select "Install from a specific location" tick the "include this location in search" click "briowse" and select the p2k drivers folder that you had downloaded. For example "D:\Motorola System\p2kdrivers_2.9" Then click "next". It will install your phone. Then again you will get the same kind of message do the same for all until it says your phone has been installed and is ready for use. Now you have done half of the job. Now run Skinman the file list will be loaded. select install.You will get a message just select ok then browse and find the theme that you want to install then select open the theme will start installing. once you have added the desired number of themes select restart phone. now you are done.
