Freezers Logo
L
Lynne Carville Posted on Mar 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wine cooler temperature
How do i make my wine fridge cooler it is on 7 at moment and i would like it to be on 4
Gil Shultz
Level 3:
  • Samsung Master 3,464 Answers
  • Posted on Apr 29, 2014
Gil Shultz
Samsung Master
Level 3:
Answers
3464
Questions
Helped
731853
Points
11104
I am not familiar with that unit but I assume you are talking degrees C. There should be a thermostat you can change. It may already be at the coldest setting, I do not know. Most of these units have a minimum temperature they will operate at, if you are at that point you will have to either change the thermostat or modify it in either case it would void the warranty.
How do i set temperature
Most fridges have only a plastic dial located somewhere in the rear of the food space inside the fridge that simply says "cooler" or "warmer" Turn this dial to change the temperature. If you want to know what the temperature is you will have to put a thermometer inside the fridge for a few minutes , open the door, and quick read the temp before the thermometer warms up. I keep a cheap thermometer with a large dial with a red indicator inside my freezer all the time and that way I can see how cold it is every time I open the freezer.
Oct 30, 2014 • Freezers
Fridgidaire freezer warming up
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 09, 2013 • Freezers
Which way do I turn the temperature dial on a true 3-door reach-in stainless steel cooler?
Numbered 1-9 - one is the warmest setting, nine is the coldest. For a cooler it should be good on 5 for a freezer 7. If it doesnt work well on those settings the thermostat is usually bad.
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
1helpful
To cold
Try 2 switch off (plug out) leave it few hour then switch on (plug in) again sometime it just error.
Liebherr wine cooler lights blinking
hello the light temperature of my leiberr wine cooler is blinking and the temperature indicates an increase in the internal temperature how to fix it?
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 • Freezers
What temperatures do the 1-7 reading on the temp. dial correspond to.
In all frdige freezers, 1-7 is -18 to -21 approx in the freezer and between 2 and 4 in the fridge. This may vary from system to system but not by much. Obviously, 7 is the coldest as this makes it the most difficult for t he thermostat to disengage.
How do I turn off the freezer section on a fridge freezer?
Unfortunately you can't. Both the fridge and freezer sections are cooled by the same compressor. You can't just have one without the other!
Matt
Apr 16, 2008 • Freezers
Top Samsung Freezers Experts
Jay Finke
Jay Finke
Arnie Burke
Arnie Burke
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
