Stoves 27 in. DW60 Built-in Dishwasher Logo
A
Anonymous Posted on Mar 27, 2014
New stoves s600dw
I've just had one delivered and can't work out how to open door we are just installing it . Instructions not clear
tip
How to install a new oven door on your electric range.
First you need to remove old oven door by opening it at a 10 or 15 degree angle and pull stright up on door,door should just slide off of the hinges.Then reposition the hinges as they spring back into the stove after old door becomes free,so position the hinges at aprox... 45 degree angle hold new door above hinges then proceed in sliding the new door on over the hinges,door should slide right in to place.KEEP FINGERS CLEAR!!!!!
Stainless steel oven finish peeling off
It is likely that the factory-installed clear plastic protective covering was not removed before the oven was placed into service.
Stainless Steel does not peel!
Ovens and other appliances with Stainless Steel finishes are made from solid sheets of the material. They are almost always sent from the factory with a protective plastic film on the finish.
Just find an edge of the appliance, and start peeling the protective film off. Pull it off slowly, as to not leave any possible residual glue or plastic on the appliance.
If the heat from the oven caused some of the plastic film to melt and it does not peel off, I would immediately call the store or dealer from which you purchased the oven and start hollering, as they did NOT properly prepare the item for sale (if it was delivered and installed).
If you purchased it in the crate/box, and installed it yourself, you must take responsibility for not having fully read the instructions before using the oven.
In that case, I would peel as much of the plastic off as is possible, and then use some LOW ODOR CLEANING SOLVENT ( or PAINT THINNER) to remove the rest, using ONLY a soft cotton towel to soak it and rub it with. Do NOT use anything abrasive or scratchy, or you will totally ruin the finish! Do NOT use the scrubber side of a sponge, or a Brillo pad, or Choreboy-type pad!
*** CAUTION!!! *** DANGER! *** The fumes and vapors from the solvent ARE EXPLOSIVE AND FLAMMABLE! DO NOT USE THE STOVE UNTIL THE VAPORS AND FUMES HAVE TOTALLY DISSIPATED!!! Open the doors or windows to the room for fresh air when you are using the solvent, and READ THE INSTRUCTIONS thoroughly!
All is not lost yet, but getting melted plastic off the stove will take some time and a very gentle touch. Be patient, and good luck.
Jul 20, 2014 • Ovens
LG stove - glass cooktop broken - model LRE30451SW/SB/ST how do i remove and replace glass cooktop on LRE30451SW/SB/ST?
Open the oven door and you should see screws on the overhang where the door fits in,take those off and that should loosen the whole top of the stove,then you will see what to do next and what you have to remove to replace what you need,hope this helps some what.
1helpful
2answers
Stove is brand new. turned oven on for 30 minutes for initial burn, open door, but it won't shut completly, why?
You don't provide a make or model number, but if it's new, look in the Owner Manual for door malfunctions. Call the store where you bought it and tell them of the problem.
Dec 18, 2009 • Ovens
We have a frigidaire stove. The bottom element has broken in two. We have purchased the new element but cannot locate our manual to show us how to install the new element. Can you give us instructions?
Hello the first thing you do is unplug the stove before doing anything ,open the oven door remove 2 screws holding the element to the back wall pull element forward remove wires with insulated pliers attached to the element ,reattach wires to new element resecure to back wall and test. good luck
6helpful
3answers
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
2answers
Oven heats up then cuts out, no light etc then comes back tolife after 5/10 mins.
Sounds like it could be the thermal cut out switch - I am having a similar problem. The switch is about £10 delivered from the Stoves spares dept. I can't work out how to open the top to change the switch though! Have you managed to solve the problem and can you add anything re opening the top?!
Brand New Machine, can't open the door
Threre should be instructions on what you need to remove, but where is this black plastic located, and wher eis the screw positioned?
Top Stoves Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Stoves Dishwasher Expert? Answer questions, earn points and help others
