Microsoft Windows XP Professional Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BaiduBar.Dll When I scan the computer and after the computer scan,I got 1 Baidubar.dll.So I choose Repair all but when I go to Add or Remove Program,I saw the baidubar.dll still there so I scan again but after the computer scan the report said ''No Virus or Unwanted Program Found!'' but when take a look at the Add or Remove Program the Baidubar.dll is still there.Could anyone help me?
Anonymous
Level 3:
  • Master 428 Answers
  • Posted on Jun 15, 2009
Anonymous
Master
Level 3:
Answers
428
Questions
Helped
189494
Points
1253
First get windows search
Go to all files and folders
Type in baidubar
select your main partition
Go to more advanced options and select
  • Search System Folders
  • Search Hidden Files and Folders
  • Search Sub Folders
Then you will see the associated files. Delete those.
Go to start and then get RUN box.
Type in regedit
Then from the menu click on find. Then find entries for baidubar.
Delete the entries (Values-Not the key). If there is only key exist then del the key.
Then find do find next until it finishes
Use windows command prompt to unregister the the dll file.
  1. To open the Windows Command Prompt, go to Start > Run > type cmd and then click the "OK" button.
  2. Type "cd" in order to change the current directory, press the "space" button, enter the full path to where you believe the BaiduBar DLL file is located and press the "Enter" button on your keyboard. If you don't know where BaiduBar DLL file is located, use the "dir" command to display the directory's contents.
  3. To unregister "BaiduBar" DLL file, type in the exact directory path + "regsvr32 /u" + [DLL_NAME] (for example, :C\Spyware-folder\> regsvr32 /u BaiduBar.dll) and press the "Enter" button. A message will pop up that says you successfully unregistered the file.
Delete other files baidubar.dat and baidubar.dll
  1. To open the Windows Command Prompt, go to Start > Run > type cmd and then press the "OK" button.
  2. Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
  3. To change directory, type in "cd name_of_the_folder".
  4. Once you have the file you're looking for type in "del name_of_the_file".
  5. To delete a file in folder, type in "del name_of_the_file".
  6. To delete the entire folder, type in "rmdir /S name_of_the_folder".
Get the task manager before doing anything and check whether a process is running like baidubar. If its there, end the process.
And get RUN box and type in msconfig
Go to "Startup" tab.
Check whether any entries there. Must be there. Then go to the location using command prompt and delete those files. If you see a registry entry there go to regedit and delete the entry.
Technical Details
File name BaiduBar.dll
File Size 1192027
MD5 Hash 29146247deb8796cdcb43993e21df63e
Anonymous
Level 1:
  • Contributor 31 Answers
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
32040
Points
95
here are some information about the normal file
http://www.file.net/process/baidubar.dll.html
If this dll is shown in Add or Remove Program, something is wrong. The normal file is not an intalled program in common sense.
Take then a look at http://www.spywareremove.com/removeBaiduBar.html
Here is a description to remove the spyware baidubar and a antispyware tool to detect it.
Hope that helps.
It just frequently pops up on the screen - t8 Ext P Ex. dll is missing
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error
Your computer will not work properly if a Windows Dynamic-Link Library (.dll) file is damaged or missing. When this happens, you will receive an error message similar to this: "[program name] Illegal system DLL relocation."
The .dll file type contains instructions, or code, to run scripts that open dialog boxes.
These important graphical elements are necessary for computer user interaction in most software programs.
There is a simple way to keep all of your .dll files healthy, so you rarely lose valuable time restoring lost or broken links.
Connect your computer to the Internet.
Click "Start" and then click "Run" if you have the Windows XP operating system. For other systems, simply open Internet Explorer and click "Safety," then click "Windows Update."
Type "wupdmgr" in the "Run" dialog box to run Microsoft Update.
Click "Express" to find out if your computer requires new updates.
Press "Install Updates" if any are available.
Otherwise, close the Microsoft Update window.
Update your anti-virus program and then immediately scan all of the files on your computer.
Open the software program that gave the .dll notice to see if error messages still occur.
If so, continue to the next step.
Reinstall the affected software program to replace the damaged or missing .DLL file.
If the issue is still not resolved, contact Microsoft Support.
Fix DLL Errors With Freeware
A Microsoft Windows DLL has data that is necessary to run various software programs.
If a DLL file is defective, the software using the file will not open or run properly.
DLL error messages can stem from a number of system issues, such as a bad program installation, registry issues and missing DLL files.
You may receive error messages from numerous programs when a DLL is corrupt, because many programs use the same DLL.
Running freeware to fix a DLL error is a viable alternative when you cannot repair the DLL manually.
Visit the Regsofts website.
Click "Download Now" to install Registry Repair 2.0.
http://www.regsofts.com/free_registry_repair/registry_repair.htm
Run the "RegpairSetup.exe" setup file.
Click "Next" at the prompts and agree to the terms of Registry Repair 2.0. Click "Finish" to open the application.
Click "Start Scan" to find DLL errors on your system. Place a check by "Non-existent Shared Dlls" once the scan completes. Click "Fix Errors" to repair the DLL errors.
Run RegSeeker 1.55
Navigate the Regsofts website.
http://www.regsofts.com/freeware/regseeker.htm
Click "Download and use for free" to install RegSeeker 1.55.
Run the "RegSeejer.zip" setup file. Click "Next" at the prompts. Agree to the terms of RegSeeker 1.55, then click "Finish" to open the tool.
Click "Clean the Registry." Allow the scan to detect and repair DLL registry issues. Reboot your system once the scan is complete.
Run ACleaner 3.5
Scroll to the bottom of the page, and click "Download and use for free" to install ACleaner 3.5.
http://www.regsofts.com/freeware/privacy-and-registry-cleaner.htm
Save and run the "ACSetup" setup file. Click "Next" at the prompts, and agree to the terms of ACleaner.
Open the software and select "Registry." Choose the Scan Registry option. Select the "fix errors" option once the scan is complete.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
3helpful
4answers
Kernel32.dll can be a problem, so my pc taking too much time to shut down
How to perform kernel32.dll repair, one common methodinvolves acquiring a new version of your kernel32.dll file and installing itright into your registry. This will fix most problems with the file- like ifit's missing or if it's still there but has become corrupted at one point oranother.
1helpful
2answers
Cannot use my pictures folder in windows XP, error reads Uxcore.d
Try re-installing uxcore.dll file.
To re-install UXCore.dll
Just follow this repair link (http://www.corruptedfilerepair.com/File-Information/UXCore.dll-Windows-Live-Client-UX-Microsoft-Corporation.asp) and download the file named UXcore.dll
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
1. Download the DLL file from the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
2. Backup the old version of the DLL file.
3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\UXCore.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\UXCore.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\UXCore.dll
Download File UXCore.dll
EXE (Executable) Files:
Steps:
1. Download the file to a folder on your computer
2. Scan the .EXE file using an Anti-Virus Scanner.
3. Run the .EXE file by double-clicking the file
ZIP/RAR Archives:
You will need to uncompress the files in the archive using WinRAR or WinZip first.
Nore : Default Location - c:\program files\windows live\installer\uxcore.dll
2answers
Ddl error message... bad image
Hi there.
You might get this if the file mcenspc.dll is leftout while uninstalling some program or when attempted to elimitate spyware or malware through spyware scan.
This has proved not to be a threat and it is safe to remove from the Computer. To do this :
1. Click Start -> Run -> Type System32 -> Ok
2. Look for mcenspc.dll
3. Right Click on the file and click Delete
4. Reboot the computer
Everything should be fine now
2answers
Trojan - antivirus-xp-pro-2009
Take my notes as a guide and hopefully this will work for you.
1. Start > Run > msconfig > “Start Up” tab > Disable All
2. “Services” tab > Check box “Hide Microsoft Services” > Disable All
2.5 Exit out, but don't reboot yet
3. Start > Right-click “My Computer” > “Properties” > “System Restore” > Check box “Turn off restore on Hard disks”
4. Start > Run > type %temp% > Edit Select All > Shift-Delete
Reboot machine
1. Combofix.exe. This program will run on its own. Also, it will likely wish to reboot the machine. Let it complete.
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
2. WinSockFix.exe. This will fix any issues with the network connection.
3. SuperAntispyware.exe. This will remove all remaining spyware, tracking cookies, and browser hijackers.
Check to see that your favorite internet browser is working. Install or re-enable your favorite antivirus that failed to catch this in the first place.
Stop WinAntiVirus2008 Processes:
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Remove WinAntiVirus2008 Registry Values:
2178F3FB-2560-458f-BDEE-631E2FE0DFE4
6F520BE0-9B54-4558-816F-224E67997DF3
459F4226-1AAB-43B6-9DC1-B6313EF83749
1AC5C88A-DEA7-462b-A232-04AF5CA42E7E
723D54C7-7483-4EB8-8EED-CE5B2AEA534D
Find and Delete these WinAntiVirus2008 Files:
WinAntiVirus Pro
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WinAntiVirus Pro.lnk
Reinstall or Uninstall WinAntiVirus Pro.lnk
WinAntiVirus Pro Manual.lnk
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Vista
Stop WinAntivirus2008 Processes:
(Learn how to do this)
WinAntivirus2008.exe
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Find and Delete these WinAntivirus2008 Files:
%UserProfile%\Desktop\Viruses.bdt
%UserProfile%\Desktop\WinAntivirus2008.lnk
c:\Program Files\WinAntivirus2008
c:\Program Files\WinAntivirus2008\Viruses.bdt
c:\Program Files\WinAntivirus2008\VRM2008.exe
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008\WinAntivirus2008.lnk
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\WinAntivirus2008.lnk
%UserProfile%\Application Data\Mozilla\Firefox\Profiles\s1jqw0bz.default\cookies.sqlite
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Remove WinAntivirus2008 Registry Values:
5222008A-DD62-49c7-A735-7BD18ECC7350
HKEY_CURRENT_USER\Software\WinAntivirus2008
WinAntivirus 2009
# 1. Find and Remove the following Antivirus 2009 Processes:
* av2009.exe
# 2. Find and Remove the following Antivirus 2009 files and folders:
* C:\Program Files\Antivirus 2009
* C:\Program Files\Antivirus 2009\av2009.exe
* c:\WINDOWS\system32\scui.cpl
* c:\WINDOWS\system32\winsrc.dll
# 3. Find and Remove the following Antivirus 2009 files and folders:
* HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\ CurrentVersion\Run\15358943642955870504508370025739
M3plugin.dll missing module at startup
Your web browser has been hijacked by "adware" called "My Web Search"... The fix is involved, but not impossible.
First, uninstall the My Web Search program using standard Add/Remove Programs. Also uninstall any of the following items associated with FunWebProducts.
  • My Web Search (Smiley Central or FWP product as applicable)
  • My Way Speedbar (Smiley Central or other FWP as applicable)
  • My Way Speedbar (AOL and Yahoo Messengers) (beta users only)
  • My Way Speedbar (Outlook, Outlook Express, and IncrediMail)
  • Search Assistant - My Way
Download a free copy of a program called HijackThis.
Reboot your Computer and run the HijackThis program.
Scan for and fix any of the entries shown below.
  • R3 - URLSearchHook: (no name) - {00A6FAF6-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL
  • O2 - BHO: MyWebSearch Search Assistant BHO - {00A6FAF1-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL
  • O2 - BHO: mwsBar BHO - {07B18EA1-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
  • O3 - Toolbar: My &Web Search - {07B18EA9-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
  • O4 - HKLM\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
  • O4 - HKCU\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
  • O4 - Startup: MyWebSearch Email Plugin.lnk = C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE
  • O4 - Global Startup: MyWebSearch Email Plugin.lnk = C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE
  • O8 - Extra context menu item: &Search - http://bar.mywebsearch.com/menusearch.html?p=ZWYYYYYYYYUS
  • O16 - DPF: {1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} - http://ak.imgfarm.com/images/nocache/funwebproducts/ei/MyWebSearchInitialSetup1.0.0.8-2.cab
Next, open My Computer, Drive C, and double-click on the Program Files folder
Right-click and delete the folders for:
  • FunWebProducts
  • MyWebSearch
MyWebSearch should now be completely uninstalled from your computer.
There will be some minor registry entries left behind by the uninstall, however these can be cleaned up by running SpyBot Search and Destroy. SpyBot is also available online as a free download.
Good luck!!
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
