it is repairable but for the cost of parts and labor you would be better of getting a new 22" LCD monitor
for the problem I would suspect the fly-back transformer or power supply
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Restart your computer.
As soon as it starts the start-up process, keep tapping the F8 key, repeatedly.
When you see the Windows "start-up" menu, select "start in safe mode".
Does your monitor work in this low-resolution (640-by-480 or 800-by-600) mode?
If so, then you had configured Windows to a too-high resolution that the NEC did not support.
Choose 1024-by-768, and click "Apply", to test that the NEC supports this mode.
Try connecting the NEC to some other computer, to see if the NEC itself is the problem.
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
