SOURCE: TV has green sceen and turns off by itself
dont do nothing with that tv go and buy a new one and thats all...good luck
SOURCE: Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
SOURCE: RCA 24V414T KEEPS TURNING OFF
it could be a ghost but most likely a bad solder connection , crystal(controls the eprom)(menu chip) , or the eprom chip itself will need to be replaced
SOURCE: I turn the tv on and after a few seconds it shuts
Possibly the main Power Regulator is damaged!!!
Open the case, then look for anything that burned out, replace it!!!
If still won't start, you need a multimeter, soldering iron, try locate output diode on power regulator board, then measure the voltages, it has 3-4 type of voltages;
first diode it should around 115V-130 V DC.
Second diode it should around 24 V DC.
Third diode it should around 11-16 V DC.
Fourth ( if exist), check diode and should around 5 V DC.
The problems usually start on second diode, if persist, follow the circuit board.
