Computer does not recognise finepix a500 not in list on scanner/camera list?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com )
Both of the two problem can be solved by 4Card Recovery. It is a kind of free recovery tool, which is able to recover all kinds of files, of course, including images. You can download it for free online.
Download it on your computer and run it.
Choose the files that you want to recover.
Scan it and save the recovered files on other part.
Pay close attention to this, do not change your old data because once it changed, you will not be able to recover it forever.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
If the images on a SmartMedia or xD-Picture Card fail to appear when the camera is connected to a Windows PC, one of the situations listed below may apply. 1. There may be a problem with the SmartMedia or xD-Picture Card. Check that the images can be viewed on the digital camera. If the images cannot be viewed on the digital camera, gently wipe the gold colored contact area on the SmartMedia or xD-Picture Card with a soft cloth and then check again. 2. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. * This only applies to models with a USB Setting or USB MODE option in the SETUP screen. 3. Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow is shown on the LCD monitor)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. 4. The USB driver may not be installed correctly. Download the USB driver from the Fujifilm general downloads web page and re-install the driver. 5. The card may not be recognized correctly if the camera is connected to an added USB interface board or via a USB hub. Always use a factory installed USB port and connect the camera directly to the USB port on the PC.
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
SOURCE: can't download images: Finepix S5800
you need to update the drivers on your computer by the sounds of things. Or alternatively re-load the software disc for the camera.
Good Luck.
SOURCE: Finepix J12 cannot upload photos onto computer.
Here's the best solution. Get a card reader for your card (available at Walmart, Kmart, Best Buy, etc.) and use it to download your pics to a folder you create on your desktop. Once there, you can do anything you like with them.
