Empty coffee ground message
Follow the message..
The drip tray sensor microswitch was stuck. Therefore the machine thought you had never removed the tray to empty ground. To fix:
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
SOURCE: Saeco Italia sensor problem
In order to reset this, you must remove the drip tray while the unit is powered up or it won't know that it has been emptied.
SOURCE: Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
SOURCE: How do I make the empty coffee grounds message go
Remove the dreg drawer on the side and wait for the message insert groungs drawer to come up, then reinsert the tray back.
SOURCE: Water leaks into side small reservoir, under the
Hi
Sounds like your drain is getting plugged with coffee residue. Remove your brw unit. There is an injector that has 2 orange o-rings in it in the back. That pocket below it is filling with water. There is a drain that is to the bottom left that goes into the drip tray in front. Use a prob of some kind that is about 12" long that you can stick down and forward in the drain pocket. Work it towards the fron and you should open the drain again. it fills with oils, so use some hot sudzy water and clean it out.
Testimonial: "Thank you sir, that was the problem. Did as you said & works without leaks again. "
