Motorola MJ270R Two Way Radio Logo
A
Anonymous Posted on Mar 26, 2014
Motorola MT352R can transmit but cannot hear
Can transmit but cannot hear
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Jan 07, 2015
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796366
Points
4248
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
2answers
Talk to others not using the motorola talkabout
Your signal might be bouncing of a building or tall structure but theirs is not, you might also be too far away, try coming in closer until you can both hold a conversation, another option is if your radio is transmitting on high and theirs is transmitting in low.
My voice does not transmit through the earpiece
Sounds like you have a problem with your microphone.
Please contact us.
Mark
Motorola Support
CONTACT US
1helpful
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
Motorola H710. When I dial out the person receiving the call cannot hear me but I can hear them via earpiece. What is the problem?
KNOWING ABOUT MOTOROLLA DEVICES
Motorola devices produce effects as one way communications. For example, device gets powered on from where user selects frequency transmission. User transmits entirely until receptacle device receives messages also replaying entirely until acquired. During the entire transmission processes, each entities waits to receive messages least expecting to transmit simultaneously. Motorola device are one way methods of sending messages also was an old fashioned method compared with recent telecommunications devices. Ascertain that a frequency has been determined from where message would be transmitted. Waiting for the receiver to reply confirms that message was transmitted. Usually with Motorola devices, alternate devices from where reception is captured waits to capture an impression. In a situation that the alternate device at an elsewhere location least transmitted a reply, reset several transitions frequencies to capture an impression as distress call from any alternate device that recognizes the caller at a frequency least prior determined.
WHAT IS EXPECTED FROM MOTOROLA DEVICES
Ascertain that the entity from where the message is derived has alternate methods of producing messages. For example, in a situation that the entity with the receptacle has another transitions device capable of being captured by the Motorola device makes an impression. For example, prior to calling contacts with the Motorola device, another entity that has means to transmit to the device being observed is heard. Ascertain that the device is capable of transmitting at several frequencies. A distress call from another device is captured from the device that has turned a frequency being transmitted distressfully. Ascertain that the caller is from a recognizable contact. In a situation that the caller is least recognizable least requiring any distressful condition requires to tune to frequency from where a recognizable entity can be captured for communications.
Mar 06, 2011 • Cell Phones
Voice recognition on motorola t5500
That means that it will Transmit, like pressing the "Talk" button, BUT ONLY when it hears the "Voice" it was "Trained" on. So this is so No-one else could use this unit. With this method. You "Identify" yourself, and after that every-time you speak, the Transmitter is keyed, and the channel is opened and the voice sent, when you stop talking,it goes back to receive, again. Some are less sophisticated, in that they are really a "Sound Switch" and when the unit "Hears" a "Voice" it, switches OFF receive, and ON the transmitter, and Transmits the audio out.
1helpful
Repeated clicking(transmitting) noise from Motorola Talkabout
Moisture and oxidation on the circuit board will create noise during transmission. You may remove the cover and wipe around microphone and the circuit.Ensure its dry. Cover it back and test.
Headset failed to transmit
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.happened to me a lot . hs850
2answers
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
