My hobart lx30h is leaking from underneath. It starts leaking gradually during fill cycle. After completing the fill when wash is pressed, it starts leaking a whole lot from underneath the washer. There is no leak in back from the back flow prevention as it's just replaced. The inside probes are clean as I checked and cleaned them. I descale regularly but do not use a softener. Not sure what the problem is? Please help.
SOURCE: Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
SOURCE: lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
SOURCE: i have a hobart lxih that is leaking from the
sounds like the wash pipe is no good , i've seen this before
