Hello, anyone could help me unlock my Nokia 2610b phone, IMEI is 011750004197445.
Hai, You can use unlock codes to unlock your Nokia 2610 mobile .
You can purchase the codes from this site Wickedunlock.com . Here they ask the country and the network name to which your mobile is locked and the imei number of the mobile. Finally they will send you the codes to unlock your mobile.
SOURCE: nokia 6110 unlock code
Hi, willimina your IMEI: 354847011991730
mastercode:
764454375x
The mastercode can be entered instead of standard security code.
and
Hi, LucasMok your IMEI: 357666019013793
mastercode:
461072065x
and the other users please let me know your IMIE number for unlock any phone.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
SOURCE: restriction code for t mobile pay as you go nokia 2610b
I bought a Nokia 2610b (IMEI:011503/00/633222/5) in USA. Now I bring it into China and use simcard in China. It is not able to work. It needs restriction code. How and where I could get it? Please anyone help me! Thanks for your kind. Please send your solution into [email protected].
SOURCE: GIVE ME THE RESTRICTED CODE OF NOKIA 2610B.
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
ENJO! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: Unlock code Request for AT&T Nokia 2610b Cell Phone
can u give me a restriction code for nokia 2610b
SOURCE: help needed to unlock Nokia 1208 on optus network
For the best unlock code for your Nokia 1208 model mobile,
you can try this site http://www.theunlockarena.com/nokia-1208/rs13wp9/
It provides the step by step instructions and easy methods for unlocking your Nokia mobile phones.............
