SOURCE: hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
SOURCE: memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
SOURCE: i keep getting a memory card error message. i am
Some computers will not acknowledge your flash cards. Depending on your flash card, your printer & computer to make sure they are compatible. Try opening your computer Icon to see if card is accepted. then click in your card to see if any file are in. You may have to load your printer software again..
time for the Geek to help!!
