Use USB cable. If your handset came with a USB cable or if you purchased a USB cable, connect your handset using the cable to your PC. Your PC should then show the contents of your Phone memory card (pictures, videos, musics) which can then be copied on to your PC. Please refer to pg. 120-125 of your Users' Manual for instructions to copy Music and Pictures.
The PDF copy of the user manual can be downloaded here: User's Guide.
hi 2 months back i took nokia 2700. from last 2 week some problem is there. the problem is a copy of msg ll took place in the last at inbox from by sent msg or saved msg. Y like this its happening its a virs problem or S/W problem. can u please help me to sort out this.... Thank U
basically nokia mode is meant only for those if u want to use ur for for internet nad short term applications..........for storage purposes data storage mode is used
this is usb issue
your computer usb has a lower version than your pendrive
you cannot use better drivers because this is from mainboard chipset
Also you can put a pci usb card version 2.0 for your pendrive
use serial cable "dku5 " and older verson of nokia pc suit."5.0".
its better to use pc suite come with the handset.
dnt use usb data cable, if u use usb cable then windows show"usb not recognise "
Data recovery software can only retrieve data if the HDD shows in windows. Some disks may not show in My Computer(if corrupted). Another way of checking if the HDD is being detected by windows is using disk management. Click Start,then run, then type compmgmt.msc. Click on Disk Management when the Computer Management box opens. If you HDD is showed among the list of drives there is a possibility of getting our data.If not you need advance data recovery where the HDD has to be physically taken apart.Let me know what your findings are.
