Tried rebooting with no change
SOURCE: Television will not program channels 2-7
It seems you have already try everything We might suggest< I dont know if you have tried using the video and audio outputs in the dvd/vcr combi unit conecting them to the audio and video imputs of your tv and the selecting maybe one of the AUX channels to watch it,If you have a tuner problem in your tv this will be a way to bypass it and control the channels from you combi unit.We would like to know the outcome,please let us know.
SOURCE: long pause changing channels
This is the muting feature. Many of these TV's use this to avoid showing noise and putting noise out to the speakers.
Run the auto-setup from the menu. This should allow the set to know the channel layout, and thus it may respond faster. Consult the user book for the auto-setup or auto-channel features.
Jerry G.
SOURCE: Change input channel
FIRSTLY consider buying a remote @ $44.95 only
get connected to
www.twenga.co.uk/dis-audio-video.home-cinema.remote-control-228-554k
to change a channel hold both channel buttons at once, your tv will give you menu and later go in programming channel
or
hold one channel button, sweep through all channels at the end you will enter AV
SOURCE: Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
SOURCE: cant watch any channel's
Is your cable bill paid, I know that some cable companies could lock your tv if you are in arrears. I hope this is not it...
